[GRASS-dev] usage of os.linesep (was: Re: [GRASS-SVN] r68240 - grass/trunk/scripts/v.report_
Martin Landa landa.martin at gmail.com
Mon Apr 11 07:58:19 PDT 2016
Hi Huidae,
{I took liberty to move discussion to ML}
2016-04-11 15:54 GMT+02:00 Huidae Cho <grass4u at gmail.com>:
> That was a copy+paste from the same script, but I think \r\n is safer than
> os.linesep just in case v.to.db prints out \r for whatever reason. But I
> know that won't happen in non-Windows anyway, so os.linesep should be fine?
hm, you are right, but still I would prefer to use os.linesep over
'\r\n'. The only problem can happen when the user will ship generated
files between Unix and Windows OS.
Any comments from others?
Thanks, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
