[GRASS-dev] [GRASS-SVN] r68256 - in grass/trunk/gui: icons/grass wxpython/datacatalog
Martin Landa landa.martin at gmail.com
Tue Apr 12 23:31:35 PDT 2016
Ahoj,
po rychlem testu:
return receiver(*arguments, **named)
  File "/opt/src/grass_trunk/dist.x86_64-pc-linux-
gnu/gui/wxpython/datacatalog/tree.py", line 363, in
OnRightClick
self._popupMenuLayer()
gnu/gui/wxpython/datacatalog/tree.py", line 725, in
_popupMenuLayer
self.selected_location.label == genv['LOCATION_NAME']:
UnboundLocalError
local variable 'genv' referenced before assignment
Ma
2016-04-13 5:20 GMT+02:00  <svn_grass at osgeo.org>:
> Author: annakrat
> Date: 2016-04-12 20:20:44 -0700 (Tue, 12 Apr 2016)
> New Revision: 68256
> Added:
>    grass/trunk/gui/icons/grass/locked.png
>    grass/trunk/gui/icons/grass/unlocked.png
> Modified:
>    grass/trunk/gui/wxpython/datacatalog/catalog.py
>    grass/trunk/gui/wxpython/datacatalog/frame.py
>    grass/trunk/gui/wxpython/datacatalog/toolbars.py
>    grass/trunk/gui/wxpython/datacatalog/tree.py
> Log:
> wxGUI: update data catalog - allow editing outside of current mapset
> Added: grass/trunk/gui/icons/grass/locked.png
> (Binary files differ)
> Property changes on: grass/trunk/gui/icons/grass/locked.png
> ___________________________________________________________________
> Added: svn:mime-type
>    + image/png
> Added: grass/trunk/gui/icons/grass/unlocked.png
> Property changes on: grass/trunk/gui/icons/grass/unlocked.png
>    + image/png
> Modified: grass/trunk/gui/wxpython/datacatalog/catalog.py
> --- grass/trunk/gui/wxpython/datacatalog/catalog.py     2016-04-12 19:57:43 UTC (rev 68255)
> +++ grass/trunk/gui/wxpython/datacatalog/catalog.py     2016-04-13 03:20:44 UTC (rev 68256)
> @@ -84,3 +84,7 @@
>      def OnReloadCurrentMapset(self, event):
>          """Reload current mapset tree only"""
>          self.tree.ReloadCurrentMapset()
> +    def SetRestriction(self, restrict):
> +        """Allow editing other mapsets or restrict editing to current mapset"""
> +        self.tree.SetRestriction(restrict)
> Modified: grass/trunk/gui/wxpython/datacatalog/frame.py
> --- grass/trunk/gui/wxpython/datacatalog/frame.py       2016-04-12 19:57:43 UTC (rev 68255)
> +++ grass/trunk/gui/wxpython/datacatalog/frame.py       2016-04-13 03:20:44 UTC (rev 68256)
> @@ -26,6 +26,7 @@
>  from datacatalog.tree import DataCatalogTree
>  from datacatalog.toolbars import DataCatalogToolbar
>  class DataCatalogFrame(wx.Frame):
>      """Frame for testing purposes only."""
>      def __init__(self, parent, giface=None):
> @@ -37,7 +38,7 @@
>          self._giface = giface
>          self.panel = wx.Panel(self)
> -        self.toolbar = DataCatalogToolbar(parent = self)
> +        self.toolbar = DataCatalogToolbar(parent=self)
>          # workaround for http://trac.wxwidgets.org/ticket/13888
>          if sys.platform != 'darwin':
>              self.SetToolBar(self.toolbar)
> @@ -46,7 +47,7 @@
>          self.tree = DataCatalogTree(parent=self.panel, giface=self._giface)
>          self.tree.InitTreeItems()
>          self.tree.ExpandCurrentMapset()
>          # buttons
>          self.btnClose = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
>          self.btnClose.SetToolTipString(_("Close GRASS GIS Data Catalog"))
> @@ -90,3 +91,7 @@
> Modified: grass/trunk/gui/wxpython/datacatalog/toolbars.py
> --- grass/trunk/gui/wxpython/datacatalog/toolbars.py    2016-04-12 19:57:43 UTC (rev 68255)
> +++ grass/trunk/gui/wxpython/datacatalog/toolbars.py    2016-04-13 03:20:44 UTC (rev 68256)
> @@ -15,15 +15,18 @@
>  import wx
> -from gui_core.toolbars import BaseToolbar, BaseIcons
> +from gui_core.toolbars import BaseToolbar
>  from icons.icon import MetaIcon
>  from core.utils import _
>  icons = {
>      'reloadTree': MetaIcon(img='redraw', label=_("Reload GRASS locations")),
> -    'reloadMapset': MetaIcon(img='reload', label=_("Reload current GRASS mapset only"))
> +    'reloadMapset': MetaIcon(img='reload', label=_("Reload current GRASS mapset only")),
> +    'unlocked': MetaIcon(img='unlocked', label=_("Click to restrict editing to current mapset only")),
> +    'locked': MetaIcon(img='locked', label=_("Click to allow editing other mapsets")),
>  class DataCatalogToolbar(BaseToolbar):
>      """Main data catalog toolbar
> @@ -44,5 +47,17 @@
>          return self._getToolbarData((("reloadTree", icons["reloadTree"],
>                                        self.parent.OnReloadTree),
>                                       ("reloadMapset", icons["reloadMapset"],
> -                                      self.parent.OnReloadCurrentMapset)
> +                                      self.parent.OnReloadCurrentMapset),
> +                                     ("lock", icons['locked'],
> +                                      self.OnSetRestriction, wx.ITEM_CHECK)
> +    def OnSetRestriction(self, event):
> +        if self.GetToolState(self.lock):
> +            self.SetToolNormalBitmap(self.lock, icons['unlocked'].GetBitmap())
> +            self.SetToolShortHelp(self.lock, icons['unlocked'].GetLabel())
> +            self.parent.SetRestriction(restrict=False)
> +        else:
> +            self.SetToolNormalBitmap(self.lock, icons['locked'].GetBitmap())
> +            self.SetToolShortHelp(self.lock, icons['locked'].GetLabel())
> +            self.parent.SetRestriction(restrict=True)
> Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
> --- grass/trunk/gui/wxpython/datacatalog/tree.py        2016-04-12 19:57:43 UTC (rev 68255)
> +++ grass/trunk/gui/wxpython/datacatalog/tree.py        2016-04-13 03:20:44 UTC (rev 68256)
> @@ -32,6 +32,7 @@
>  from grass.pydispatch.signal import Signal
>  import grass.script as gscript
> +from grass.script import gisenv
>  from grass.exceptions import CalledModuleError
> @@ -50,7 +51,7 @@
>      return tmp_gisrc_file, env
> -def getLocationTree(gisdbase, location, queue, mapsets=[]):
> +def getLocationTree(gisdbase, location, queue, mapsets=None):
>      """Creates dictionary with mapsets, elements, layers for given location.
>      Returns tuple with the dictionary and error (or None)"""
>      tmp_gisrc_file, env = getEnvironment(gisdbase, location, 'PERMANENT')
> @@ -92,6 +93,64 @@
>      gscript.try_remove(tmp_gisrc_file)
> +def map_exists(name, element, env, mapset=None):
> +    """Check is map is present in the mapset given in the environment
> +    :param name: name of the map
> +    :param element: data type ('raster', 'raster_3d', and 'vector')
> +    :param env environment created by function getEnvironment
> +    if not mapset:
> +        mapset = gscript.run_command('g.mapset', flags='p', env=env).strip()
> +    # change type to element used by find file
> +    if element == 'raster':
> +        element = 'cell'
> +    elif element == 'raster_3d':
> +        element = 'grid3'
> +    # g.findfile returns non-zero when file was not found
> +    # se we ignore return code and just focus on stdout
> +    process = gscript.start_command('g.findfile', flags='n',
> +                                    element=element, file=name, mapset=mapset,
> +                                    stdout=gscript.PIPE, stderr=gscript.PIPE, env=env)
> +    output, errors = process.communicate()
> +    info = gscript.parse_key_val(output, sep='=')
> +    # file is the key questioned in grass.script.core find_file()
> +    # return code should be equivalent to checking the output
> +    if info['file']:
> +        return True
> +    else:
> +        return False
> +class NameEntryDialog(TextEntryDialog):
> +    def __init__(self, element, mapset, env, **kwargs):
> +        TextEntryDialog.__init__(self, **kwargs)
> +        self._element = element
> +        self._mapset = mapset
> +        self._env = env
> +        id_OK = self.GetAffirmativeId()
> +        self.Bind(wx.EVT_BUTTON, self.OnOK, self.FindWindowById(id_OK))
> +    def OnOK(self, event):
> +        new = self.GetValue()
> +        if not new:
> +            return
> +        if map_exists(new, self._element, self._env, self._mapset):
> +            dlg = wx.MessageDialog(self, message=_("Map of type {elem} <{name}> already exists in mapset <{mapset}>. "
> +                                                   "Do you want to overwrite it?").format(elem=self._element,
> +                                   name=new, mapset=self._mapset),
> +                                   caption=_("Overwrite?"), style=wx.YES_NO)
> +            if dlg.ShowModal() == wx.ID_YES:
> +                dlg.Destroy()
> +                self._env['GRASS_OVERWRITE'] = '1'
> +                self.EndModal(wx.ID_OK)
> +            else:
> +                dlg.Destroy()
> +                return
> +        else:
>  class DataCatalogNode(DictNode):
>      """Node representing item in datacatalog."""
>      def __init__(self, label, data=None):
> @@ -122,15 +181,16 @@
>          self.parent = parent
>          self.contextMenu.connect(self.OnRightClick)
>          self.itemActivated.connect(self.OnDoubleClick)
>          self._initVariables()
>      def _initTreeItems(self, locations=None, mapsets=None):
>          """Add locations, mapsets and layers to the tree.
>          Runs in multiple processes. Saves resulting data and error."""
>          # mapsets param currently unused
> +        genv = gisenv()
>          if not locations:
> -            locations = GetListOfLocations(self.gisdbase)
> +            locations = GetListOfLocations(genv['GISDBASE'])
>          loc_count = proc_count = 0
>          queue_list = []
> @@ -141,13 +201,13 @@
>              nprocs = cpu_count()
>          except NotImplementedError:
>                  nprocs = 4
>          results = dict()
>          errors = []
>          location_nodes = []
>          nlocations = len(locations)
>          grassdata_node = self._model.AppendNode(parent=self._model.root,
> -                                                label=_('GRASS locations ({})').format(self.gisdbase),
> +                                                label=_('GRASS locations in {}').format(genv['GISDBASE']),
>                                                  data=dict(type='grassdata'))
>          for location in locations:
>              results[location] = dict()
> @@ -160,7 +220,7 @@
>              q = Queue()
>              p = Process(target=getLocationTree,
> -                        args=(self.gisdbase, location, q))
> +                        args=(genv['GISDBASE'], location, q))
>              p.start()
>              queue_list.append(q)
> @@ -212,6 +272,7 @@
>                  child = None
>              return child
> +        genv = gisenv()
>          locationItem, mapsetItem = self.GetCurrentLocationMapsetNode()
>          if not locationItem or not mapsetItem:
>              return
> @@ -224,11 +285,11 @@
>          q = Queue()
> -                    args=(self.gisdbase, locationItem.data['name'], q, mapsetItem.data['name']))
> +                    args=(genv['GISDBASE'], locationItem.data['name'], q, mapsetItem.data['name']))
>          p.start()
>          maps, error = q.get()
>          if error:
> -            raise CalledModuleError(e)
> +            raise CalledModuleError(error)
>          self._populateMapsetItem(mapsetItem, maps[mapsetItem.data['name']])
>          self.RefreshNode(mapsetItem)
> @@ -251,6 +312,10 @@
>          """Create popup menu for mapsets"""
>          raise NotImplementedError()
> +    def _popupMenuElement(self):
> +        """Create popup menu for elements"""
> +        raise NotImplementedError()
>      def _initVariables(self):
>          """Init variables."""
>          self.selected_layer = None
> @@ -258,11 +323,6 @@
>          self.selected_mapset = None
>          self.selected_location = None
> -        gisenv = gscript.gisenv()
> -        self.gisdbase = gisenv['GISDBASE']
> -        self.glocation = gisenv['LOCATION_NAME']
> -        self.gmapset = gisenv['MAPSET']
>      def GetControl(self):
>          """Returns control itself."""
>          return self
> @@ -279,7 +339,7 @@
>              self.selected_layer = item
>              type = 'element'
>              item = item.parent
>          if type == 'element':
>              self.selected_type = item
>              type = 'mapset'
> @@ -289,20 +349,22 @@
>              self.selected_mapset = item
>              type = 'location'
>              item = item.parent
>          if type == 'location':
>              self.selected_location = item
>      def OnSelChanged(self, event):
>      def OnRightClick(self, node):
>          """Display popup menu."""
>          self.DefineItems(node)
>          if self.selected_layer:
> -            self._popupMenuLayer(self.selected_mapset.label == self.gmapset)
> +            self._popupMenuLayer()
>          elif self.selected_mapset and not self.selected_type:
>              self._popupMenuMapset()
> +        elif self.selected_type:
> +            self._popupMenuElement()
>      def OnDoubleClick(self, node):
>          """Expand/Collapse node."""
> @@ -310,7 +372,7 @@
>              self.CollapseNode(node, recursive=False)
>          else:
>              self.ExpandNode(node, recursive=False)
>      def ExpandCurrentLocation(self):
>          """Expand current location"""
>          location = gscript.gisenv()['LOCATION_NAME']
> @@ -323,9 +385,9 @@
>      def GetCurrentLocationMapsetNode(self):
>          """Get current mapset node"""
> -        location = gisenv['LOCATION_NAME']
> -        mapset = gisenv['MAPSET']
> +        genv = gisenv()
> +        location = genv['LOCATION_NAME']
> +        mapset = genv['MAPSET']
>          locationItem = self._model.SearchNodes(name=location, type='location')
>          if not locationItem:
>              return None, None
> @@ -335,7 +397,7 @@
>              return locationItem[0], None
>          return locationItem[0], mapsetItem[0]
>      def ExpandCurrentMapset(self):
>          """Expand current mapset"""
> @@ -343,11 +405,13 @@
>              self.Select(mapsetItem, select=True)
>              self.ExpandNode(mapsetItem, recursive=True)
>  class DataCatalogTree(LocationMapTree):
>          """Data Catalog Tree constructor."""
>          super(DataCatalogTree, self).__init__(parent)
> +        self._restricted = True
>          self._initVariablesCatalog()
>          self.beginDrag = Signal('DataCatalogTree.beginDrag')
> @@ -356,18 +420,18 @@
>          self.endEdit = Signal('DataCatalogTree.endEdit')
>          self.Bind(wx.EVT_TREE_BEGIN_DRAG, lambda evt:
> -            self._emitSignal(evt.GetItem(), self.beginDrag, event=evt))
> +                  self._emitSignal(evt.GetItem(), self.beginDrag, event=evt))
>          self.Bind(wx.EVT_TREE_END_DRAG, lambda evt:
> -            self._emitSignal(evt.GetItem(), self.endDrag, event=evt))
> +                  self._emitSignal(evt.GetItem(), self.endDrag, event=evt))
>          self.beginDrag.connect(self.OnBeginDrag)
>          self.endDrag.connect(self.OnEndDrag)
>          self.Bind(wx.EVT_TREE_BEGIN_LABEL_EDIT, lambda evt:
> -            self._emitSignal(evt.GetItem(), self.startEdit, event=evt))
> +                  self._emitSignal(evt.GetItem(), self.startEdit, event=evt))
>          self.Bind(wx.EVT_TREE_END_LABEL_EDIT, lambda evt:
> -            self._emitSignal(evt.GetItem(), self.endEdit, event=evt))
> -        ###self.startEdit.connect(self.OnStartEditLabel)
> -        ###self.endEdit.connect(self.OnEditLabel)
> +                  self._emitSignal(evt.GetItem(), self.endEdit, event=evt))
> +        self.startEdit.connect(self.OnStartEditLabel)
> +        self.endEdit.connect(self.OnEditLabel)
>      def _initVariablesCatalog(self):
> @@ -376,17 +440,20 @@
>          self.copy_mapset = None
>          self.copy_location = None
> +        self._restricted = restrict
>      def _runCommand(self, prog, **kwargs):
>          cmdString = ' '.join(gscript.make_command(prog, **kwargs))
>          ret = RunCommand(prog, parent=self, **kwargs)
>          return ret, cmdString
>      def InitTreeItems(self):
>          """Add locations, mapsets and layers to the tree."""
>          self._initTreeItems()
> -    def OnCopy(self, event):
> +    def OnCopyMap(self, event):
>          """Copy layer or mapset (just save it temporarily, copying is done by paste)"""
>          self.copy_layer = self.selected_layer
>          self.copy_type = self.selected_type
> @@ -394,15 +461,17 @@
>          self.copy_location = self.selected_location
>          label = _("Map <{layer}> marked for copying. "
>                    "You can paste it to the current mapset "
> -                  "<{mapset}>.".format(layer=self.copy_layer.label, mapset=self.gmapset))
> +                  "<{mapset}>.".format(layer=self.copy_layer.label, mapset=gisenv()['MAPSET']))
>          self.showNotification.emit(message=label)
> -    def OnRename(self, event):
> -        """Rename levent with dialog"""
> -        if self.selected_layer:
> -            self.old_name = self.selected_layer.label
> -            self.new_name = self._getUserEntry(_('New name'), _('Rename map'), self.old_name)
> -            self.Rename()
> +    def OnRenameMap(self, event):
> +        """Rename layer with dialog"""
> +        old_name = self.selected_layer.label
> +        gisrc, env = getEnvironment(gisenv()['GISDBASE'], self.selected_location.label, mapset=self.selected_mapset.label)
> +        new_name = self._getNewMapName(_('New name'), _('Rename map'),
> +                                       old_name, env=env, mapset=self.selected_mapset.label, element=self.selected_type.label)
> +        if new_name:
> +            self.Rename(old_name, new_name)
>      def OnStartEditLabel(self, node, event):
>          """Start label editing"""
> @@ -416,51 +485,44 @@
>      def OnEditLabel(self, node, event):
>          """End label editing"""
>          if self.selected_layer and not event.IsEditCancelled():
> -            self.old_name = node.label
> -            Debug.msg(1, "End label edit {name}".format(name=self.old_name))
> -            self.new_name = event.GetLabel()
> -            self.Rename()
> +            old_name = node.label
> +            Debug.msg(1, "End label edit {name}".format(name=old_name))
> +            new_name = event.GetLabel()
> -    def Rename(self):
> +    def Rename(self, old, new):
>          """Rename layer"""
> -        if self.selected_layer and self.new_name:
> -            string = self.old_name + ',' + self.new_name
> -            gisrc, env = getEnvironment(self.gisdbase, self.selected_location.label, self.selected_mapset.label)
> -            renamed = 0
> -            label = _("Renaming map <{name}>...").format(name=string)
> -            self.showNotification.emit(message=label)
> -            if self.selected_type.label == 'vector':
> -                renamed, cmd = self._runCommand('g.rename', vector=string, env=env)
> -            elif self.selected_type.label == 'raster':
> -                renamed, cmd = self._runCommand('g.rename', raster=string, env=env)
> -            else:
> -                renamed, cmd = self._runCommand('g.rename', raster3d=string, env=env)
> -            if renamed == 0:
> -                self.selected_layer.label = self.new_name
> -                self.selected_layer.data['name'] = self.new_name
> -                self.RefreshNode(self.selected_layer)
> -                self.showNotification.emit(message=_("{cmd} -- completed").format(cmd=cmd))
> -                Debug.msg(1, "LAYER RENAMED TO: " + self.new_name)
> -            gscript.try_remove(gisrc)
> +        string = old + ',' + new
> +        gisrc, env = getEnvironment(gisenv()['GISDBASE'], self.selected_location.label, self.selected_mapset.label)
> +        label = _("Renaming map <{name}>...").format(name=string)
> +        self.showNotification.emit(message=label)
> +        if self.selected_type.label == 'vector':
> +            renamed, cmd = self._runCommand('g.rename', vector=string, env=env)
> +        elif self.selected_type.label == 'raster':
> +            renamed, cmd = self._runCommand('g.rename', raster=string, env=env)
> +        else:
> +            renamed, cmd = self._runCommand('g.rename', raster3d=string, env=env)
> +        if renamed == 0:
> +            self.selected_layer.label = new
> +            self.selected_layer.data['name'] = new
> +            self.RefreshNode(self.selected_layer)
> +            self.showNotification.emit(message=_("{cmd} -- completed").format(cmd=cmd))
> +            Debug.msg(1, "LAYER RENAMED TO: " + new)
> +        gscript.try_remove(gisrc)
> -    def OnPaste(self, event):
> -        """Paste layer or mapset"""
> +    def OnPasteMap(self, event):
> +        """Paste layer"""
>          # copying between mapsets of one location
>          if not self.copy_layer:
>              GMessage(_("No map selected for copying."), parent=self)
>              return
> -        if self.selected_location == self.copy_location and \
> -           self.selected_mapset.data['name'] == gscript.gisenv()['MAPSET']:
> -            if self.selected_type:
> -                if self.copy_type.label != self.selected_type.label:  # copy raster to vector or vice versa
> -                    GError(_("Failed to copy map: invalid map type "
> -                             "({} vs. {}).".format(self.copy_type.label, self.selected_type.label)), parent=self)
> -                    return
> -            self.new_name = self._getUserEntry(_('New name'), _('Copy map'),
> -                                               self.copy_layer.label + '_copy')
> -            if not self.new_name:
> +        if self.selected_location == self.copy_location:
> +            new_name = self._getNewMapName(_('New name'), _('Copy map'),
> +                                           self.copy_layer.label, env=env, mapset=self.selected_mapset.label, element=self.copy_type.label)
> +            if not new_name:
>                  return
> -            if self.copy_layer.label == self.new_name:
> +            if map_exists(new_name, element=self.copy_type.label, env=env, mapset=self.selected_mapset.label):
>                  GMessage(_("Failed to copy map: new map has the same name"), parent=self)
>                  return
> @@ -470,21 +532,21 @@
>              overwrite = False
> -                found = self._model.SearchNodes(parent=self.selected_type, type=self.copy_type.label, name=self.new_name)
> +                found = self._model.SearchNodes(parent=self.selected_type, type=self.copy_type.label, name=new_name)
>                  if found and found[0]:
>                      dlg = wx.MessageDialog(parent=self,
> -                                           message = _("Map <{map}> already exists "
> -                                                       "in the current mapset. "
> -                                                       "Do you want to overwrite it?").format(map=self.new_name),
> -                                           caption = _("Overwrite?"),
> -                                           style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
> +                                           message=_("Map <{map}> already exists "
> +                                                     "in the current mapset. "
> +                                                     "Do you want to overwrite it?").format(map=new_name),
> +                                           style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
>                      ret = dlg.ShowModal()
>                      dlg.Destroy()
>                      if ret == wx.ID_YES:
>                          overwrite = True
> -            string = self.copy_layer.label + '@' + self.copy_mapset.label + ',' + self.new_name
> +            string = self.copy_layer.label + '@' + self.copy_mapset.label + ',' + new_name
>              pasted = 0
>              label = _("Copying <{name}>...").format(name=string)
> @@ -498,60 +560,63 @@
>                  pasted, cmd = self._runCommand('g.copy', raster_3d=string, overwrite=overwrite, env=env)
>                  node = 'raster_3d'
>              if pasted == 0:
> -                if not self.selected_type:
> -                    # add type node if not exists
> -                    self.selected_type = self._model.AppendNode(parent=self.selected_mapset, label=node,
> -        data=dict(type='element', name=node))
> -                if not overwrite:
> -                    self._model.AppendNode(parent=self.selected_type, label=self.new_name,
> -                                           data=dict(type=node, name=self.new_name))
> -                    self._model.SortChildren(self.selected_type)
> -                    self.RefreshNode(self.selected_type, recursive=True)
> -                Debug.msg(1, "COPIED TO: " + self.new_name)
> -                self.showNotification.emit(message= _("{cmd} -- completed").format(cmd=cmd))
> +                self.InsertLayer(name=new_name, mapset_node=self.selected_mapset, element_name=node)
> +                Debug.msg(1, "COPIED TO: " + new_name)
> +                self.showNotification.emit(message=_("g.copy completed").format(cmd=cmd))
>          else:
> -            if self.selected_location != self.copy_location:
> -                GError(_("Failed to copy map: action is allowed only within the same location."),
> -                       parent=self)
> -            else:
> -                GError(_("Failed to copy map: action is allowed only within the current mapset."),
> -                       parent=self)
> +            GError(_("Failed to copy map: action is allowed only within the same location."),
> +                   parent=self)
>          # expand selected mapset
>          self.ExpandNode(self.selected_mapset, recursive=True)
> -    def OnDelete(self, event):
> +    def InsertLayer(self, name, mapset_node, element_name):
> +        """Insert layer into model and refresh tree"""
> +        found_element = self._model.SearchNodes(parent=mapset_node, type='element', name=element_name)
> +        found_element = found_element[0] if found_element else None
> +        if not found_element:
> +            # add type node if not exists
> +            found_element = self._model.AppendNode(parent=mapset_node, label=element_name,
> +                                                   data=dict(type='element', name=element_name))
> +        found = self._model.SearchNodes(parent=found_element, name=name)
> +        if len(found) == 0:
> +            self._model.AppendNode(parent=found_element, label=name,
> +                                   data=dict(type=element_name, name=name))
> +            self._model.SortChildren(found_element)
> +            self.RefreshNode(mapset_node, recursive=True)
> +    def OnDeleteMap(self, event):
>          """Delete layer or mapset"""
> -            string = self.selected_layer.label
> -            removed = 0
> -            # TODO: rewrite this that it will tell map type in the dialog
> -            if self._confirmDialog(question=_('Do you really want to delete map <{m}>?').format(m=string),
> -                                   title=_('Delete map')) == wx.ID_YES:
> -                label = _("Deleting {name}...").format(name=string)
> -                    removed, cmd = self._runCommand('g.remove', flags='f', type='vector',
> -                                         name=string, env=env)
> -                    removed, cmd = self._runCommand('g.remove', flags='f', type='raster',
> -                else:
> -                    removed, cmd = self._runCommand('g.remove', flags='f', type='raster_3d',
> -                if removed == 0:
> -                    self._model.RemoveNode(self.selected_layer)
> -                    Debug.msg(1, "LAYER " + string + " DELETED")
> +        name = self.selected_layer.label
> +        if self._confirmDialog(question=_("Do you really want to delete map <{m}> of type <{etype}> from mapset "
> +                               "<{mapset}> in location <{loc}>?").format(m=name, mapset=self.selected_mapset.label,
> +        etype=self.selected_type.label,
> +        loc=self.selected_location.label),
> +                               title=_('Delete map')) == wx.ID_YES:
> +            label = _("Deleting {name}...").format(name=name)
> +                removed, cmd = self._runCommand('g.remove', flags='f', type='vector',
> +                                                name=name, env=env)
> +                removed, cmd = self._runCommand('g.remove', flags='f', type='raster',
> +            else:
> +                removed, cmd = self._runCommand('g.remove', flags='f', type='raster_3d',
> +            if removed == 0:
> +                self._model.RemoveNode(self.selected_layer)
> +                self.RefreshNode(self.selected_type, recursive=True)
> +                Debug.msg(1, "LAYER " + name + " DELETED")
> +                self.showNotification.emit(message=_("g.remove completed").format(cmd=cmd))
>      def OnDisplayLayer(self, event):
>          """Display layer in current graphics view"""
>          layerName = []
> -        if self.selected_location.label == self.glocation and self.selected_mapset:
> +        if self.selected_location.label == gisenv()['LOCATION_NAME'] and self.selected_mapset:
>              string = self.selected_layer.label + '@' + self.selected_mapset.label
>              layerName.append(string)
>              label = _("Displaying {name}...").format(name=string)
> @@ -573,35 +638,39 @@
>      def OnBeginDrag(self, node, event):
>          """Just copy necessary data"""
> -        if wx.GetMouseState().ControlDown():
> -            #cursor = wx.StockCursor(wx.CURSOR_HAND)
> -            #self.SetCursor(cursor)
> +        self.DefineItems(node)
> +        if self.selected_layer and \
> +           not (self._restricted and gisenv()['LOCATION_NAME'] != self.selected_location.label):
>              event.Allow()
> -            self.DefineItems(node)
> -            self.OnCopy(event)
> +            self.OnCopyMap(event)
>              Debug.msg(1, "DRAG")
>          else:
>              event.Veto()
> -            Debug.msg(1, "DRAGGING without ctrl key does nothing")
>      def OnEndDrag(self, node, event):
>          """Copy layer into target"""
> -        #cursor = wx.StockCursor(wx.CURSOR_ARROW)
> +        if not wx.GetMouseState().ControlDown():
> +            GMessage(_("Moving maps not implemented"), parent=self)
> +            event.Veto()
> +            return
>          if node:
> +            if self._restricted and gisenv()['MAPSET'] != self.selected_mapset.label:
> +                GMessage(_("Maps can be copied only to current mapset"), parent=self)
> +                event.Veto()
> +                return
>              if self.selected_location == self.copy_location and self.selected_mapset:
>                  event.Allow()
> -                self.OnPaste(event)
> -                #cursor = wx.StockCursor(wx.CURSOR_DEFAULT)
> -                #self.SetCursor(cursor) # TODO: change cursor while dragging and then back, this is not working
> +                self.OnPasteMap(event)
>                  Debug.msg(1, "DROP DONE")
>              else:
>                  event.Veto()
> -    def _getUserEntry(self, message, title, value):
> +    def _getNewMapName(self, message, title, value, element, mapset, env):
>          """Dialog for simple text entry"""
> -        dlg = TextEntryDialog(self, message, title)
> +        dlg = NameEntryDialog(parent=self, message=message, caption=title,
> +                              element=element, env=env, mapset=mapset)
>          dlg.SetValue(value)
>          if dlg.ShowModal() == wx.ID_OK:
>              name = dlg.GetValue()
> @@ -618,28 +687,43 @@
>          dlg.Destroy()
>          return res
> -    def _popupMenuLayer(self, current_mapset):
> +    def _popupMenuLayer(self):
>          """Create popup menu for layers"""
>          menu = wx.Menu()
> +        if self._restricted:
> +            genv = gisenv()
> +            currentMapset = currentLocation = False
> +            if self.selected_location.label == genv['LOCATION_NAME']:
> +                currentLocation = True
> +                if self.selected_mapset.label == genv['MAPSET']:
> +                    currentMapset = True
> +        else:
> +            currentMapset = currentLocation = True
>          item = wx.MenuItem(menu, wx.NewId(), _("&Copy"))
>          menu.AppendItem(item)
> -        self.Bind(wx.EVT_MENU, self.OnCopy, item)
> +        self.Bind(wx.EVT_MENU, self.OnCopyMap, item)
> +        item.Enable(currentLocation)
> -        item = wx.MenuItem(menu, wx.NewId(), _("&Delete"))
> +        item = wx.MenuItem(menu, wx.NewId(), _("&Paste"))
> -        self.Bind(wx.EVT_MENU, self.OnDelete, item)
> -        if not current_mapset:
> +        self.Bind(wx.EVT_MENU, self.OnPasteMap, item)
> +        if not(currentLocation and self.copy_layer and self.selected_location == self.copy_location):
>              item.Enable(False)
> +        item = wx.MenuItem(menu, wx.NewId(), _("&Delete"))
> +        menu.AppendItem(item)
> +        self.Bind(wx.EVT_MENU, self.OnDeleteMap, item)
> +        item.Enable(currentMapset)
>          item = wx.MenuItem(menu, wx.NewId(), _("&Rename"))
> -        self.Bind(wx.EVT_MENU, self.OnRename, item)
> -            item.Enable(False)
> +        self.Bind(wx.EVT_MENU, self.OnRenameMap, item)
> -        if not isinstance(self._giface, StandaloneGrassInterface):
> -            item = wx.MenuItem(menu, wx.NewId(), _("&Display"))
> +        if not isinstance(self._giface, StandaloneGrassInterface) and \
> +           self.selected_location.label == genv['LOCATION_NAME']:
> +            item = wx.MenuItem(menu, wx.NewId(), _("&Display layer"))
>              self.Bind(wx.EVT_MENU, self.OnDisplayLayer, item)
> @@ -652,7 +736,21 @@
> -        self.Bind(wx.EVT_MENU, self.OnPaste, item)
> +        if not (self.copy_layer and self.selected_location == self.copy_location):
> +            item.Enable(False)
>          self.PopupMenu(menu)
>          menu.Destroy()
> +        menu = wx.Menu()
> +        self.PopupMenu(menu)
> +        menu.Destroy()
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
