[GRASS-dev] [GRASS GIS] #2996: Lidar modules broken in 64bit WinGRASS
GRASS GIS trac at osgeo.org
Wed Apr 20 15:02:55 PDT 2016
 Reporter:  wenzeslaus                           |      Owner:  grass-dev@…
     Type:  defect                               |     Status:  new
 Priority:  blocker                              |  Milestone:  7.0.4
Component:  Packaging                            |    Version:  svn-
 Keywords:  lasinfo, r.in.lidar, v.in.lidar,     |  releasebranch70
  r3.in.lidar, libLAS                            |        CPU:  x86-64
 Platform:  Unspecified                          |
 `lasinfo`, `r.in.lidar` and `v.in.lidar` are broken in 64bit version of
 7.0.4svn (r68280) and 7.1.svn (r68287). The modules are present, show GUI
 and show help but will fail to work with any file (tried two, one is
 [http://courses.ncsu.edu/mea582/common/media/01/0793_016.las.zip here]).
 `lasinfo` fails as well. Possible commands:
 lasinfo 0793_016.las
 r.in.lidar -e input=0793_016.las output=n method=n resolution=5 -o
 System Info
 GRASS version: 7.1.svn
 GRASS SVN revision: r68287
 Build date: 2016-04-20
 Build platform: x86_64-w64-mingw32
 GDAL: 2.0.2
 PROJ.4: 4.9.2
 GEOS: 3.5.0
 SQLite: 3.7.17
 Python: 2.7.5
 wxPython: 2.8.12.1
 Platform: Windows-8-6.2.9200
 Running them with `--help` works as well as e.g. `r.in.gdal` works in the
 64bit version.
 In 32bit version (7.0.4RC1 and 7.1.svn), `lasinfo` and `r.in.lidar` work:
 Build platform: i386-w64-mingw32
 GDAL: 2.0.2
 PROJ.4: 4.9.2
 GEOS: 3.5.0
 SQLite: 3.7.17
 Python: 2.7.4
 wxPython: 2.8.12.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/2996>
