[GRASS-dev] GRASS 7.1 trunk still will not compile on Mac
Michael Barton Michael.Barton at asu.edu
Thu Apr 21 16:15:37 PDT 2016
I tried today to compile GRASS 7.1 on the Mac using ONLY 64 bit architecture, instead of the dual 32/64 bit hack I've been using for the past several years. It compiled fine. But it requires using 64bit wxPython 3.0.2.0. This wxPython 3 GUI mostly works but still has some glitches.
So here are a few questions.
1. Was there some change so that GRASS 7.1 now only compiles 64 bit? It compiled with dual architecture in early December 2015 but I have been unable to get to compile with the same config string since then.
2. If it is only 64 bit now, it seems that there needs to be some tweaking on the GUI. Are we ready to move to wxPython 3.x and deal with that? If so, I can easily start to compile 7.0 in 64 bit when those are ironed out.
3. If the answer to #1 is yes, I can go ahead and post a 64bit wxPython 3 version to the Mac site so that people can try it out and report bugs to fix. Should I do that?
Thanks
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Apr 20, 2016, at 5:35 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
After compiling 7.0.4RC1, I tried again to compile 7.1. Previously, several modules would not compile. I did an svn update and got the same result. So I deleted all files and updated to a clean copy of trunk. Now nothing will compile. An example error is below. It seems to relate to 64 bit architecture.
Any suggestions?
[Important note: I am compiling binaries for the Mac community, not for myself. So that means not using HomeBrew or other package manager like systems for Mac]
Michael
make: *** [default] Error 1
cmb-imaccsdc:grass_trunk cmbarton$ cd /Users/cmbarton/grass_source/grass_trunk/lib/gis
cmb-imaccsdc:gis cmbarton$ make
cc -dynamiclib -compatibility_version 7.1 -current_version 7.1 -install_name /Applications/GRASS-7.1.app/Contents/MacOS/lib/libgrass_gis.7.1.svn.dylib -o /Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.5.0/lib/libgrass_gis.7.1.svn.dylib -L/Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.5.0/lib -L/Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.5.0/lib -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.8.sdk   -L/usr/local/lib   OBJ.x86_64-apple-darwin14.5.0/adj_cellhd.o OBJ.x86_64-apple-darwin14.5.0/alloc.o OBJ.x86_64-apple-darwin14.5.0/area.o OBJ.x86_64-apple-darwin14.5.0/area_ellipse.o OBJ.x86_64-apple-darwin14.5.0/area_poly1.o OBJ.x86_64-apple-darwin14.5.0/area_poly2.o OBJ.x86_64-apple-darwin14.5.0/area_sphere.o OBJ.x86_64-apple-darwin14.5.0/ascii_chk.o OBJ.x86_64-apple-darwin14.5.0/asprintf.o OBJ.x86_64-apple-darwin14.5.0/basename.o OBJ.x86_64-apple-darwin14.5.0/bres_line.o OBJ.x86_64-apple-darwin14.5.0/clicker.o OBJ.x86_64-apple-darwin14.5.0/cmprbzip.o OBJ.x86_64-apple-darwin14.5.0/cmprlz4.o OBJ.x86_64-apple-darwin14.5.0/cmprrle.o OBJ.x86_64-apple-darwin14.5.0/cmprzlib.o OBJ.x86_64-apple-darwin14.5.0/color_rules.o OBJ.x86_64-apple-darwin14.5.0/color_str.o OBJ.x86_64-apple-darwin14.5.0/commas.o OBJ.x86_64-apple-darwin14.5.0/compress.o OBJ.x86_64-apple-darwin14.5.0/copy_dir.o OBJ.x86_64-apple-darwin14.5.0/copy_file.o OBJ.x86_64-apple-darwin14.5.0/counter.o OBJ.x86_64-apple-darwin14.5.0/date.o OBJ.x86_64-apple-darwin14.5.0/datum.o OBJ.x86_64-apple-darwin14.5.0/debug.o OBJ.x86_64-apple-darwin14.5.0/distance.o OBJ.x86_64-apple-darwin14.5.0/done_msg.o OBJ.x86_64-apple-darwin14.5.0/endian.o OBJ.x86_64-apple-darwin14.5.0/env.o OBJ.x86_64-apple-darwin14.5.0/error.o OBJ.x86_64-apple-darwin14.5.0/file_name.o OBJ.x86_64-apple-darwin14.5.0/find_etc.o OBJ.x86_64-apple-darwin14.5.0/find_file.o OBJ.x86_64-apple-darwin14.5.0/find_rast.o OBJ.x86_64-apple-darwin14.5.0/find_rast3d.o OBJ.x86_64-apple-darwin14.5.0/find_vect.o OBJ.x86_64-apple-darwin14.5.0/geodesic.o OBJ.x86_64-apple-darwin14.5.0/geodist.o OBJ.x86_64-apple-darwin14.5.0/get_ellipse.o OBJ.x86_64-apple-darwin14.5.0/get_projinfo.o OBJ.x86_64-apple-darwin14.5.0/get_window.o OBJ.x86_64-apple-darwin14.5.0/getl.o OBJ.x86_64-apple-darwin14.5.0/gisbase.o OBJ.x86_64-apple-darwin14.5.0/gisdbase.o OBJ.x86_64-apple-darwin14.5.0/gisinit.o OBJ.x86_64-apple-darwin14.5.0/handler.o OBJ.x86_64-apple-darwin14.5.0/home.o OBJ.x86_64-apple-darwin14.5.0/ilist.o OBJ.x86_64-apple-darwin14.5.0/intersect.o OBJ.x86_64-apple-darwin14.5.0/is.o OBJ.x86_64-apple-darwin14.5.0/key_value1.o OBJ.x86_64-apple-darwin14.5.0/key_value2.o OBJ.x86_64-apple-darwin14.5.0/key_value3.o OBJ.x86_64-apple-darwin14.5.0/key_value4.o OBJ.x86_64-apple-darwin14.5.0/legal_name.o OBJ.x86_64-apple-darwin14.5.0/line_dist.o OBJ.x86_64-apple-darwin14.5.0/list.o OBJ.x86_64-apple-darwin14.5.0/ll_format.o OBJ.x86_64-apple-darwin14.5.0/ll_scan.o OBJ.x86_64-apple-darwin14.5.0/locale.o OBJ.x86_64-apple-darwin14.5.0/location.o OBJ.x86_64-apple-darwin14.5.0/lrand48.o OBJ.x86_64-apple-darwin14.5.0/ls.o OBJ.x86_64-apple-darwin14.5.0/ls_filter.o OBJ.x86_64-apple-darwin14.5.0/lz4.o OBJ.x86_64-apple-darwin14.5.0/mach_name.o OBJ.x86_64-apple-darwin14.5.0/make_loc.o OBJ.x86_64-apple-darwin14.5.0/make_mapset.o OBJ.x86_64-apple-darwin14.5.0/mapcase.o OBJ.x86_64-apple-darwin14.5.0/mapset.o OBJ.x86_64-apple-darwin14.5.0/mapset_msc.o OBJ.x86_64-apple-darwin14.5.0/mapset_nme.o OBJ.x86_64-apple-darwin14.5.0/mkstemp.o OBJ.x86_64-apple-darwin14.5.0/myname.o OBJ.x86_64-apple-darwin14.5.0/named_colr.o OBJ.x86_64-apple-darwin14.5.0/nl_to_spaces.o OBJ.x86_64-apple-darwin14.5.0/nme_in_mps.o OBJ.x86_64-apple-darwin14.5.0/open.o OBJ.x86_64-apple-darwin14.5.0/open_misc.o OBJ.x86_64-apple-darwin14.5.0/overwrite.o OBJ.x86_64-apple-darwin14.5.0/pager.o OBJ.x86_64-apple-darwin14.5.0/parser.o OBJ.x86_64-apple-darwin14.5.0/parser_dependencies.o OBJ.x86_64-apple-darwin14.5.0/parser_help.o OBJ.x86_64-apple-darwin14.5.0/parser_html.o OBJ.x86_64-apple-darwin14.5.0/parser_interface.o OBJ.x86_64-apple-darwin14.5.0/parser_rest.o OBJ.x86_64-apple-darwin14.5.0/parser_script.o OBJ.x86_64-apple-darwin14.5.0/parser_standard_options.o OBJ.x86_64-apple-darwin14.5.0/parser_wps.o OBJ.x86_64-apple-darwin14.5.0/paths.o OBJ.x86_64-apple-darwin14.5.0/percent.o OBJ.x86_64-apple-darwin14.5.0/plot.o OBJ.x86_64-apple-darwin14.5.0/pole_in_poly.o OBJ.x86_64-apple-darwin14.5.0/popen.o OBJ.x86_64-apple-darwin14.5.0/progrm_nme.o OBJ.x86_64-apple-darwin14.5.0/proj1.o OBJ.x86_64-apple-darwin14.5.0/proj2.o OBJ.x86_64-apple-darwin14.5.0/proj3.o OBJ.x86_64-apple-darwin14.5.0/put_window.o OBJ.x86_64-apple-darwin14.5.0/putenv.o OBJ.x86_64-apple-darwin14.5.0/radii.o OBJ.x86_64-apple-darwin14.5.0/rd_cellhd.o OBJ.x86_64-apple-darwin14.5.0/remove.o OBJ.x86_64-apple-darwin14.5.0/rename.o OBJ.x86_64-apple-darwin14.5.0/rhumbline.o OBJ.x86_64-apple-darwin14.5.0/rotate.o OBJ.x86_64-apple-darwin14.5.0/seek.o OBJ.x86_64-apple-darwin14.5.0/set_window.o OBJ.x86_64-apple-darwin14.5.0/short_way.o OBJ.x86_64-apple-darwin14.5.0/sleep.o OBJ.x86_64-apple-darwin14.5.0/snprintf.o OBJ.x86_64-apple-darwin14.5.0/spawn.o OBJ.x86_64-apple-darwin14.5.0/strings.o OBJ.x86_64-apple-darwin14.5.0/tempfile.o OBJ.x86_64-apple-darwin14.5.0/timestamp.o OBJ.x86_64-apple-darwin14.5.0/token.o OBJ.x86_64-apple-darwin14.5.0/trim_dec.o OBJ.x86_64-apple-darwin14.5.0/units.o OBJ.x86_64-apple-darwin14.5.0/user_config.o OBJ.x86_64-apple-darwin14.5.0/verbose.o OBJ.x86_64-apple-darwin14.5.0/view.o OBJ.x86_64-apple-darwin14.5.0/whoami.o OBJ.x86_64-apple-darwin14.5.0/win32_pipes.o OBJ.x86_64-apple-darwin14.5.0/wind_2_box.o OBJ.x86_64-apple-darwin14.5.0/wind_format.o OBJ.x86_64-apple-darwin14.5.0/wind_in.o OBJ.x86_64-apple-darwin14.5.0/wind_limits.o OBJ.x86_64-apple-darwin14.5.0/wind_overlap.o OBJ.x86_64-apple-darwin14.5.0/wind_scan.o OBJ.x86_64-apple-darwin14.5.0/window_map.o OBJ.x86_64-apple-darwin14.5.0/worker.o OBJ.x86_64-apple-darwin14.5.0/wr_cellhd.o OBJ.x86_64-apple-darwin14.5.0/writ_zeros.o OBJ.x86_64-apple-darwin14.5.0/xdr.o OBJ.x86_64-apple-darwin14.5.0/zero.o OBJ.x86_64-apple-darwin14.5.0/zone.o  -lgrass_datetime.7.1.svn  -lz   -lintl   -liconv
Undefined symbols for architecture x86_64:
  "___sincos_stret", referenced from:
      _G_begin_geodesic_equation in geodesic.o
      _G_geodesic_lat_from_lon in geodesic.o
      _G_set_geodesic_distance_lat2 in geodist.o
      _G_geodesic_distance in geodist.o
      _G_rotate_around_point in rotate.o
      _G_rotate_around_point_int in rotate.o
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make: *** [/Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.5.0/lib/libgrass_gis.7.1.svn.dylib] Error 1
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160421/4e1907f7/attachment-0003.html>
