[GRASS-dev] [GRASS GIS] #2456: read CSV from GDAL data directory
Markus Neteler neteler at osgeo.org
Mon Apr 25 15:27:49 PDT 2016
Hi Paul,
thanks for your patience and the explanations!
n Mon, Apr 25, 2016 at 11:15 PM, Paul Kelly
<paul-grass at stjohnspoint.co.uk> wrote:
> I would suggest the attached patch to solve both problems (taking into
> account Helena's comments that NAD83 HARN should be separate).
> Paul
I have now submitted the changes along with the addition of some code
comments as per your emails in:
https://trac.osgeo.org/grass/changeset/68308
Hope I got it right! If yes, I'll backport that.
Now I have recompiled trunk and made a new test with SIRGAS2000 (seems
to be an interesting test case besides Krovak):
grass71 -c epsg:4674 ~/grassdata/SIRGAS2000
GRASS 7.1.svn (SIRGAS2000):~ > g.proj -w
PROJCS["SIRGAS 2000",
    GEOGCS["grs80",
        DATUM["Sistema_de_Referencia_Geocentrico_para_las_AmericaS_2000",
            SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]]]
... which still differs from ...
GRASS 7.1.svn (SIRGAS2000):~ > testepsg epsg:4674
Validate Succeeds.
WKT[epsg:4674] =
GEOGCS["SIRGAS 2000",
        SPHEROID["GRS 1980",6378137,298.257222101,
            AUTHORITY["EPSG","7019"]],
        TOWGS84[0,0,0,0,0,0,0],
        AUTHORITY["EPSG","6674"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9122"]],
    AUTHORITY["EPSG","4674"]]
The main difference is that GRASS actually generates it as PROJCS
while GDAL generates it as GEOGCS. Hence a reverse test of the g.proj
output checked in testepsg fails at time.
thanks
Markus
