[GRASS-dev] [GRASS GIS] #3002: r.tile incorrect overlapping
GRASS GIS trac at osgeo.org
Tue Apr 26 04:06:51 PDT 2016
 Reporter:  aardgoose    |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.0.4
Component:  Default      |    Version:  svn-trunk
 Keywords:               |        CPU:  x86-64
 Platform:  MSWindows 8  |
 r.tile using an overlap of 1 overlaps adjacent tiles by 2 columns,
 illustrated by the r.info extract below. Resolution is 32m and overlap S
 -N of is 64m.
  | Map:      TEXTZ-000-000 at SK               Date: Tue Apr 26 11:52:03 2016
  | Title:    Tile 0,0 of SK32M ( TEXTZ-000-000 )
  | Timestamp: none
  |   Type of Map:  raster               Number of Categories: 0
  |   Data Type:    DCELL
  |   Rows:         100
  |   Columns:      100
  |   Total Cells:  10000
  |        Projection: Transverse Mercator
  |            N: 390031.98976328    S: 386833.0134357   Res: 31.98976328
  |            E: 403166.31130064    W: 399968.01705757   Res: 31.98294243
  |   Range of data:    min = 149.215669047674  max = 373.009547999747
  |   Data Source:
  |    SK32M
  |   Data Description:
  |    generated by r.tile
  |   Comments:
  |    r.tile --verbose input="SK32M" output="TEXTZ" width=98 height=98
 ove\   |
  |    rlap=1
  | Map:      TEXTZ-001-000 at SK               Date: Tue Apr 26 11:52:03 2016
  | Title:    Tile 0,1 of SK32M ( TEXTZ-001-000 )
  | Timestamp: none
  |   Data Type:    DCELL
  |   Rows:         100
  |   Columns:      100
  |   Total Cells:  10000
  |            N: 386896.99296225    S: 383698.01663468   Res: 31.98976328
  |   Range of data:    min = 127.552440611917  max = 409.305838621671
  |   Data Source:
  |    SK32M
  |   Data Description:
  |    generated by r.tile
  |   Comments:
 ove\   |
  |    rlap=1
Ticket URL: <http://trac.osgeo.org/grass/ticket/3002>
