[GRASS-dev] [GRASS GIS] #3006: Large attribute table causes buffer overflow in v.db.select
GRASS GIS trac at osgeo.org
Wed Apr 27 13:51:56 PDT 2016
  Reporter:  marisn       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.1.0
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  v.db.select
       CPU:  Unspecified  |   Platform:  Linux
Comment (by annakrat):
 Replying to [comment:2 marisn]:
 > Replying to [comment:1 annakrat]:
 > > Aren't these 2 separate issues? First is v.db.select crashing and
 second is opening large tables in attribute table manager.
 > I haven't been reading the code, still I believe the overflow is caused
 by behaviour of wxGUI as it happened when I was trying to view attribute
 table of vector map. The question is if we should fix v.db.selec as many
 parts of GRASS would fail if abused (just grep for fixed buffer sizes in C
 files to get an idea).
 The backtrace comes from v.db.select, so we should start there. Loading
 data in attribute manager is separate issue. Run v.db.select from command
 line, you should get the backtrace. But to fix it we need reproducible
 example, so if you can't reproduce it on North Carolina, your data is
 needed or at least a way to generate the data which lead to the crash.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3006#comment:3>
