[GRASS-dev] [GRASS-SVN] r68329 - grass/trunk/lib/gis
Vaclav Petras wenzeslaus at gmail.com
Fri Apr 29 06:20:12 PDT 2016
On Fri, Apr 29, 2016 at 6:33 AM, <svn_grass at osgeo.org> wrote:
>  # v.db.select
>  v.db.select|nv:null_value
> +v.db.select|fs:separator
>  v.db.select|vs:vertical_separator
Shouldn't the "global block" in renamed_options take care of nv and fs?
### Global
fs:separator
nv:null_value
dt:dtime
dp:precision
The command:
v.db.select bridges fs=comma
works for me in trunk in r68324 (i.e. before r68329) and gives expected
warning (Please update the usage of <v.db.select>: option <fs> has been
renamed to <separator>).
https://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/renamed_options?rev=68329
https://trac.osgeo.org/grass/changeset/68329
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160429/e1d9e52c/attachment-0001.html>
