[GRASS-dev] grass 7.2 planning
Martin Landa landa.martin at gmail.com
Sat Apr 30 05:09:30 PDT 2016
2016-04-29 15:09 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> I have some things in lidar modules which would be good to do before the
> branching, namely changing the layer options to flag(s) and removal of
> vector output from r.in.lidar. Ideally, some code should go from modules to
> the library but that might not be feasible in the given time frame (from my
> side). The first week of May I can't promise any commits since I'm at FOSS4G
> NA [1]
we can wait one week or so if you wish.
> From things I remember, there is the prototype of Simple Python Editor which
> needs a review but you (Martin) already did some, so I guess that's fine.
Yes, I used the editor in lessons. Nice tool! I had only one problem,
sometimes run button was not working (I discovered why after lesson
[1] :-)
Ma
[1] https://trac.osgeo.org/grass/ticket/2997
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
