[GRASS-dev] [GRASS GIS] #3112: wxgui scatterplot tool: C++ assertion "m_window" failed at ../src/gtk/dcclient.cpp(2043) in DoGetSize(): GetSize() doesn't work without window
GRASS GIS trac at osgeo.org
Wed Aug 3 07:47:21 PDT 2016
without window
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.5
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  scatterplot
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by annakrat):
 Then it makes sense, your version of wxPython has fixed the original
 problem, but now a different problem appears (apparently only for wxGTK).
 There are some clues in the ticket you link, but I am not sure if it
 helps. If I can reproduce it on my system I'll try to look at it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3112#comment:4>
