[GRASS-dev] [GRASS GIS] #3121: d.barscale and northarrow positioning problem when off-screen rendering
GRASS GIS trac at osgeo.org
Sun Aug 7 12:35:07 PDT 2016
  Reporter:  kuszinger    |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Display      |    Version:  svn-trunk
Resolution:               |   Keywords:  d.northarrow, d.barscale
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by annakrat):
 Replying to [comment:2 annakrat]:
 > In [changeset:"69100" 69100]:
 > #!CommitTicketReference repository="" revision="69100"
 > d.barscale: fix layout when using frame, see #3121
 Could you please test d.barscale in trunk? If it's ok, then we can fix the
 other d. commands in the same way.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3121#comment:3>
