[GRASS-dev] [SoC] GSoC: Basic cartography suite in GRASS - Week 10
Veronica Andreo veroandreo at gmail.com
Mon Aug 8 08:09:34 PDT 2016
It works for me in the wxGUI (grass trunk r69093M).
Did you install the add-on? It works if you also have the add-on installed
2016-08-08 12:04 GMT-03:00 Moritz Lennert <mlennert at club.worldonline.be>:
> On 05/08/16 04:06, Anna Petrášová wrote:
>> On Mon, Aug 1, 2016 at 4:34 AM, Moritz Lennert
>> <mlennert at club.worldonline.be> wrote:
>>> Adam,
>>> On 31/07/16 20:50, Adam Laža wrote:
>>>> Hi all,
>>>> below is my tenth week report.
>>>> Best regards,
>>>> Adam
>>>> Wiki page:
>>>> https://trac.osgeo.org/grass/wiki/GSoC/2016/BasicCartography
>>>> SuiteInGRASS
>>>> Week 10, July, 25 - July, 29
>>>> 1. What did you get done this week?
>>>> I fixed a bug in d.legend module [1]
>>>> I worked on d.legend.vect module. I implemented the vector legend for
>>>> GUI and d.mon.
>>>> I designed some symbols for area and line vector maps.
>>>> 2. What do you plan on doing next week?
>>>> I will continue work on vector legend.
>>> Great work on the cartography front !!
>>> Another idea for the vector legend: add a frequency histogram next to the
>>> legend to see how many objects are in each class. A bit like the
>>> histogram
>>> feature of the raster legend for continuous data (would be nice to have
>>> that
>>> for categorized data as well).
>>> Just to keep you busy ;-)
>> I suggest to create an enhancement ticket for that because we won't
>> get to it in this GSoC and this nice idea could get lost.
>> BTW, I committed the first version of the vector legend, so you can
>> test it in trunk. You still have to run:
>> g.extension d.legend.vect
> I haven't been able to get it to work, neither in the wxGUI nor with a
> d.mon wx monitor. Is there a short howto somewhere ?
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160808/f5cca23c/attachment.html>
