[GRASS-dev] [GRASS GIS] #2368: Python version of r.grow does not support shrinking
GRASS GIS trac at osgeo.org
Tue Aug 9 01:27:45 PDT 2016
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:              |     Status:  new
  enhancement            |
  Priority:  minor       |  Milestone:  7.2.0
 Component:  Raster      |    Version:  svn-trunk
Resolution:              |   Keywords:  r.grow, r.grow.distance, r.buffer,
       CPU:              |  r.buffer.lowmem
  Unspecified            |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:12 mmetz]:
 > Replying to [comment:9 neteler]:
 > > Replying to [comment:7 neteler]:
 > > > Replying to [comment:6 mmetz]:
 > > > > Replying to [comment:3 glynn]:
 > > > > > The easiest change would be to have an "invert" flag which
 caused the distance= map to contain the distance from the nearest null
 cell (currently, it's the distance from the nearest non-null cell, so the
 non-null cells themselves have a distance of 0).
 > > > > Attached is a minimally invasive patch to add a new flag to
 r.grow.distance, calculating the distance to the nearest null cell.
 > > > Patch applied to trunk in r67620.
 > > Can I backport this to 7.2.0? Again I need a negative buffer...
 > This is a new feature and as such does not qualify for backport.
 > If you want to shrink you can use
 > r.mapcalc "input_inv = if(isnull(input), 1, null())"
 > r.grow input=input_inv
 I meant r.grow.distance, not r.grow.
 > Replying to [comment:10 neteler]:
 > > Just tested r.grow with a negative radius and the following error
 occurs:
 > > # NC sample dataset
 > > v.in.region box
 > > v.to.rast input=box output=box use=val val=1
 > > r.grow input=box output=box_shrink radius=-20.01
 > The example is wrong because there are no NULL cells in the current
 region for the input raster. When growing, for each NULL cell the distance
 to the nearest non-NULL cell is calculated. When shrinking, for each non-
 NULL cell the distance to the nearest NULL cell is calculated. That means
 there must be both NULL and non-NULL cells in the input raster for the
 current region, otherwise nothing can be grown or shrunk.
 > The example can not work because r.grow does not support negative
 distances.
 Support for shrinking with negative radius added to r.grow in r69110.
 Please try the example in the manual.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2368#comment:13>
