[GRASS-dev] [GRASS GIS] #3125: d.legend.vect: take into account size_column/width_column in legend
GRASS GIS trac at osgeo.org
Tue Aug 9 11:11:00 PDT 2016
  Reporter:  mlennert    |      Owner:  grass-dev@…
      Type:              |     Status:  new
  enhancement            |
  Priority:  normal      |  Milestone:  7.0.5
 Component:  Default     |    Version:  unspecified
Resolution:              |   Keywords:  d.legend.vect, gsoc2016, symbol
       CPU:              |  size
  Unspecified            |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:1 mlennert]:
 > One related issue that should be dealt with ASAP: when doing
 proportionate symbols with size_column, the size parameter for symbols
 represents a scaling factor, not a size. However, d.legend.vect uses it as
 a size indicator meaning that when you set your scaling factor to a small
 value (values can easily close to zero, such as 0.001) the symbol in the
 legend also becomes very small.
 > Probably the best solution would be to allow the use d.legend.vect's
 symbol_size also for symbols, maybe through a flag to d.legend.vect ("Use
 symbol_size also for point symbols").
 I've added a patch to show what I mean, but I'm acting a bit blindly,
 here, for lack of thorough understanding of d.legend.vect, so this
 definitely needs to be checked.
Ticket URL: <http://trac.osgeo.org/grass/ticket/3125#comment:2>
