[GRASS-dev] Errored: GRASS-GIS/grass-ci#1438 (master - 5442e14)
Markus Neteler neteler at osgeo.org
Wed Aug 10 13:28:09 PDT 2016
does anyone see the issue?
thanks
Markus
On Wed, Aug 10, 2016 at 9:46 PM, Travis CI <builds at travis-ci.org> wrote:
> *GRASS-GIS / grass-ci <https://travis-ci.org/GRASS-GIS/grass-ci>* (master
> <https://github.com/GRASS-GIS/grass-ci/tree/master>)
> Build #1438 has errored.
> <https://travis-ci.org/GRASS-GIS/grass-ci/builds/151312098>
> 25 minutes and 57 seconds
> *Markus Neteler* 5442e14
> <https://github.com/GRASS-GIS/grass-ci/commit/5442e144bdccc2fcd009cd308a02b275d987c20b> Changeset
>> <https://github.com/GRASS-GIS/grass-ci/compare/f8c3980ba725...5442e144bdcc>
>   appdata.xml: updated with appstream-util tool
> git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69119
> 15284696-431f-4ddb-bdfa-cd5b030d7da7
> *System message:*
> We are seeing build failures due to new sudo-enabled Precise and Trusty
> images. See more details here
> <https://www.traviscistatus.com/incidents/11hp8bhkrkn7>. Thank you for
> your enduring patience.
> *Want to know about upcoming build environment updates?*
> Would you like to stay up-to-date with the upcoming Travis CI build
> environment updates? We set up a mailing list for you! Sign up here
> <http://eepurl.com/9OCsP>.
> Documentation <https://docs.travis-ci.com> about Travis CI
> For help please join our IRC channel irc.freenode.net#travis.
> Choose who receives these build notification emails in your configuration
> file <https://docs.travis-ci.com/user/notifications>.
> *Would you like to test your private code?*
> Travis CI for Private Projects
> <https://travis-ci.com?utm_source=build_email_footer&utm_campaign=travis-ci.org&utm_medium=email>
> could be your new best friend!
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160810/2f6cba34/attachment-0001.html>
