[GRASS-dev] [GRASS GIS] #3119: r.out., gdal -c should not write Metadata: COLOR_TABLE_RULE_RGB
GRASS GIS trac at osgeo.org
Fri Aug 12 02:26:27 PDT 2016
#3119: r.out.,gdal -c  should not write Metadata: COLOR_TABLE_RULE_RGB
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.out.gdal
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:2 neteler]:
 > Thanks.
 > Just an idea: should -c trigger -m automatically or is there any -c use
 case where the GRASS color rules are still wanted in the metadata?
 The main purpose of -c is to suppress those long color tables for UInt16
 in GTiff: one separate entry for each possible value which makes rendering
 very slow. GTiff color tables and GRASS color rules are not the same, e.g.
 a simple GRASS color rule such as
 0 black
 255 white
 is expanded to 256 entries for Byte. GRASS r.in.gdal prefers GRASS color
 rules as custom metadata over standard color tables, therefore these GRASS
 color rules are wanted also with the -m flag. BTW, earlier versions of
 QGIS also recognized these GRASS color rules. Format-dependent color
 tables as such are not custom metadata, the GDAL driver decides if the
 selected format supports color tables. Therefore I would regard the -c and
 -m flags as independent of each other.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3119#comment:3>
