[GRASS-dev] [GRASS GIS] #2252: wxGUI vector digitizer passing unescaped text to database
GRASS GIS trac at osgeo.org
Sun Aug 21 06:08:33 PDT 2016
  Reporter:  marisn      |      Owner:  grass-dev@…
      Type:  defect      |     Status:  closed
  Priority:  critical    |  Milestone:  7.0.5
 Component:  wxGUI       |    Version:  svn-trunk
Resolution:  fixed       |   Keywords:  security, code injection, SQL
       CPU:              |  injection, data loss, v.db.update
  Unspecified            |   Platform:  Unspecified
Changes (by annakrat):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Replying to [comment:16 marisn]:
 > After backporting, this ticket should be closed, as original issue has
 been solved. Parameter binding is a more complicated issue and thus should
 be addressed in a separate bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2252#comment:19>
