[GRASS-dev] [GRASS GIS] #2229: error in projection definition
GRASS GIS trac at osgeo.org
Sun Aug 21 12:40:51 PDT 2016
  Reporter:  vincent             |      Owner:  grass-dev@…
      Type:  defect              |     Status:  new
  Priority:  normal              |  Milestone:  7.0.5
 Component:  Projections/Datums  |    Version:  svn-releasebranch70
Resolution:                      |   Keywords:  pseudomercator
       CPU:  Unspecified         |   Platform:  Unspecified
Comment (by martinl):
 Replying to [comment:15 vincent]:
 > Or should GRASS be aware of the parameter EXTENSION ?
 > EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext
 +no_defs"]
 I think GDAL should be aware of that not GRASS (which is using GDAL
 function to translate EPSG code).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2229#comment:16>
