[GRASS-dev] [GRASS GIS] #2456: read CSV from GDAL data directory
GRASS GIS trac at osgeo.org
Mon Aug 22 07:37:54 PDT 2016
  Reporter:  martinl             |      Owner:  grass-dev@…
      Type:  task                |     Status:  new
  Priority:  blocker             |  Milestone:  7.0.5
 Component:  Projections/Datums  |    Version:  svn-releasebranch70
Resolution:                      |   Keywords:  gdal, g.proj
       CPU:  Unspecified         |   Platform:  Unspecified
Comment (by neteler):
 After discussion with Even Rouault at the FOSS4G 2016 code sprint and some
 testing with m.proj
  * removal of local copies of NAD and datum shift files which are indeed
 used from GDAL
  * extended documentation in lib/proj/README.txt
 Done in r69211.
 After extensive testing backport candidate. Test values available in
 https://github.com/OSGeo/proj.4/tree/master/nad . Test cases should be
 implemented with m.proj.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2456#comment:33>
