[GRASS-dev] [GRASS GIS] #2318: G7: t.* modules unclear -s flag
GRASS GIS trac at osgeo.org
Tue Aug 23 13:50:28 PDT 2016
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.5
 Component:  Temporal     |    Version:  svn-releasebranch70
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by veroandreo):
 Replying to [comment:2 martinl]:
 > Still an issue?
 AFAIU, yes.
 Check for example: [https://grass.osgeo.org/grass70/manuals/t.select.html
 t.select],
 [https://grass.osgeo.org/grass70/manuals/t.sample.html t.sample],
 [https://grass.osgeo.org/grass70/manuals/t.topology.html t.topology]
 In grass70 there's still also -s flag in
 [https://grass.osgeo.org/grass70/manuals/t.rast.aggregate.html
 t.rast.aggregate], while that was already changed to suffix parameter in
 72 and trunk.
 Then, [https://grass.osgeo.org/grass70/manuals/t.rast.univar.html
 t.rast.univar] uses -s to suppress printing of column names in 70, 72 and
 trunk.
 In 72 and trunk, t.rast.algebra uses -s to activate spatial topology
 (there's no t.rast.algebra in 70); t.rast.mapcalc in 70, 72 and trunk uses
 -s to check for spatial overlap.
 -s is used differently across t.* modules
Ticket URL: <https://trac.osgeo.org/grass/ticket/2318#comment:3>
