[GRASS-dev] [GRASS GIS] #3135: Pressing Run button in GUI dialogs open a new dialog
GRASS GIS trac at osgeo.org
Sat Aug 27 02:23:56 PDT 2016
 Reporter:  martinl      |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  critical     |  Milestone:  7.0.5
Component:  wxGUI        |    Version:  svn-trunk
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 Some modules is not possible to run from the GUI. Steps to reproduce:
 1. Open the GUI (`g.gui`)
 2. Go to 'Console' and type `t.list`
 3. New dialog appears
 3. Press `Run` button to run the module
 4. Instead of running the module a new GUI dialog for the module appears
 There are probably more modules affected (those with no option required).
 Note when running the module from terminal (`t.list --ui`) the dialog
 works as expected.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3135>
