[GRASS-dev] Modified i.rgb.his
Nikos Alexandris nik at nikosalexandris.net
Tue Aug 30 13:28:54 PDT 2016
Nikos Alexandris wrote:
> > Attached here-in a slightly updated diff (from the last diff attached in
> > #774) for i.rgb.his.
> > I need time to learn/understand things (in C). Yet, I tested the "new"
> > version and it works for me.
> > I would like to push this version into SVN myself. Thus, I'd like to ask
> > (in the grass-psc list) for commit access. However, I can just submit
> > another, updated, diff, in ticket #774 for someone to take over.
Moritz Lennert:
>Please do that. Core svn access takes time, and in any case it is better
>to have everything documented in the trac ticket.
Absolutely.
>When I apply this patch I get some compiler warning that need to be
>fixed first.
>Also, could you please document the bit_depth parameter in i.rgb.his.html ?
>One thing I don't understand about the results:
>Using the NC landsat images and running
>i.rgb.his r=lsat7_2002_30 g=lsat7_2002_20 bl=lsat7_2002_10 h=h8 i=i8 s=s8 bit_depth=8
>and
>i.rgb.his r=lsat7_2002_30 g=lsat7_2002_20 bl=lsat7_2002_10 h=h16 i=i16 s=s16 bit_depth=16
>I then get for intensity:
> > r.info -r i8
>min=0.08431373
>max=1
> > r.info -r i16
>min=0.000328069
>max=0.003891051
>Is this expected, or is there an issue with scaling the 16-bit version
>between 0 and 1 ?
Yes, expected. The correct way to compare is:
# raw input is 8-bit
for BAND in 10 20 30; do echo "Band ${BAND}:" `r.info -r lsat7_2002_${BAND}` ;done
Band 10: min=42 max=255
Band 20: min=28 max=255
Band 30: min=1 max=255
# thus, rescale to 16-bit
for BAND in 10 20 30; do r.rescale lsat7_2002_$BAND from=0,255 output=lsat7_2002_${BAND}_16 to=0,65535 ;done
# then convert
i.rgb.his r=lsat7_2002_30_16 g=lsat7_2002_20_16 bl=lsat7_2002_10_16 h=h16 i=i16 s=s16 bit_depth=16
# now "input" will be
for BAND in 10 20 30; do echo "Band ${BAND}:" `r.info -r lsat7_2002_${BAND}_16` ;done
Band 10: min=0 max=65536
Band 20: min=0 max=65535
Band 30: min=0 max=65535
# maybe wrong the above -- should use real "min" instead of 0?
# then compare
for DIMENSION in h s i; do echo `echo "${DIMENSION}  8:" && r.info -r ${DIMENSION}8` && echo `echo -e "${DIMENSION} 16:" && r.info -r ${DIMENSION}16` ;done
h 8: min=0 max=359.434
h 16: min=0 max=359.434
s 8: min=0 max=1
s 16: min=0 max=1
i 8: min=0.08431373 max=1
i 16: min=0.08431373 max=1
Several points to discuss/answer:
- Autodetect input's bitness?
- Still enable the user to control input bitness -- We can imagine to
  even instruct `bit_depth=11` or `bit_depth=12`. Makes sense?
- 8-bit (or any bitness!) images should fail to convert, and report, in
  case the user tries to "fake" them as being 16-bit (or higher than
  what the input really is)
- A test for an open half ended range, ie [0, 2^bit-depth),
  is required too. That is inputs ranging in [0, 2^bit-depth] should
  fail. Makes sense?
- Still to do: set hue to NULL if chroma = 0
- More?
Nikos
