[GRASS-dev] t.register ruins end timestamps
Veronica Andreo
veroandreo at gmail.com
Thu Dec 1 00:22:06 PST 2016
Hi Martin,
Some time ago, I tried to exemplify most ways of registering maps in time
series in this wiki:
https://grasswiki.osgeo.org/wiki/Temporal_data_processing/maps_registration
please, change and enhance as needed :)
Vero
2016-12-01 9:19 GMT+01:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Skip the interval option, it is not required if you specify a time
> interval in the raster metadata or in an input file.
> 2016-12-01 9:17 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
>> Hi,
>> 2016-12-01 9:10 GMT+01:00 Luca Delucchi <lucadeluge at gmail.com>:
>> >> $ r.timestamp clip_LT51910262011267KIS01_B1
>> >> 24 Sep 2011 09:39:44 / 24 Sep 2011 09:39:44
>> >> After registration to spatial-temporal dataset:
>> >> $ t.register inp=test maps=clip_LT51910262011267KIS01_B
>> yes, but than t.register fails:
>> t.register inp=test maps=clip_LT51910262011267KIS01_B1 --o -i
>> WARNING: Temporal database connection defined as:
>> /work/geodata/grassdata/zddp-landsat/PERMANENT/tgis/sqlite.db
>> But database file does not exist.
>> ERROR: The interval flag requires the start option
>> Start option should be taken from timestamp, or? Ma
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161201/d78639f7/attachment-0001.html>
