[GRASS-dev] remove layer from vector map
Moritz Lennert mlennert at club.worldonline.be
Tue Dec 6 23:20:46 PST 2016
Le 7 décembre 2016 07:29:16 GMT+01:00, Paulo van Breugel <p.vanbreugel at gmail.com> a écrit :
>Hi, seems like a basic question, but can't seem to find how to remove
>an
>attribute layer. There is an option to remove a layer in the attribute
>table manager if it is linked to a table (in the remove layer tab under
>manage layer). But this only removes the attribute table it seems. When
>I
>query a map afterwards, it still shows results for two layers. Also, I
>can't find a command for on the command line to remove a layer.
>From memory:
v.category YourMap op=del cat=-1 layer=YourLayer
Moritz
