[GRASS-dev] Source code link in Addons
Veronica Andreo veroandreo at gmail.com
Thu Dec 15 00:01:49 PST 2016
Hi :)
I checked what Markus says, and yes the links appear in addons if I
call g.manual some-addon from 72 or 73, but I am not redirected to the
source code. Instead, I get the following:
Trac Error
No node grass/trunk/home/veroandreo/tmp/grass7-veroandreo-18093/tmppTzxLm/t.rast.out.xyz
at revision 70080
Do you get the same or is something in my PC only?
Thanks much!
Vero
2016-12-14 22:23 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> Hi Luca,
> On Wed, Dec 14, 2016 at 3:39 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> Hi devs,
>> a power user ask me to implement source code link also in Addons, so I
>> looked a little bit to the code and it seems it should work already.
>> During addon compilation Script.make is called, inside this there is
>> Html.make, this is calling mkhtml.py that contains the code to add
>> "Source code", so I don't understand why this is not added (with wrong
>> url) to the HTML file?
> I think it all works. The point is that the Addons on the Web site are
> compiled against V7.0.svn while only V7.2.svn comes with the new
> source code/history link.
> As soon as we enable building the addons against 7.2. it will be included.
> In local 7.2 installations, with g.extension, the manual of addons
> contains the desired links (try with g.manual someaddon).
> So I think it is all working, just not yet visible on the Web site.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
