[GRASS-dev] [GRASS GIS] #3229: r.what - add option to use column as input label
GRASS GIS trac at osgeo.org
Wed Dec 21 03:29:52 PST 2016
 Reporter:  pvanbosgeo   |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  normal       |  Milestone:  7.0.6
Component:  Default      |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 As input for r.what locations are specified as geographic x,y coordinate
 pairs and optionally a label for each location.
 An alternative input is to use a point vector layer (parameter points). In
 this case, it is not possible, as far as I can tell, to define a label for
 each location.
 Feature request: when using a point vector layer as input, add the option
 to define a column from the vector's attribute table as label.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3229>
