[GRASS-dev] [GRASS GIS] #2912: raster_what() not compliant with localised version of GRASS
GRASS GIS trac at osgeo.org
Wed Feb 17 10:54:03 PST 2016
  Reporter:  andbal  |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  major   |  Milestone:  7.0.4
 Component:  Python  |    Version:  svn-trunk
Resolution:          |   Keywords:  grass.script python translation
       CPU:  x86-64  |   Platform:  Linux
Comment (by annakrat):
 Replying to [comment:7 lucadelu]:
 > Replying to [comment:6 annakrat]:
 > > I didn't like the gui parameter, perhaps `localized=False` would make
 more sense when you want to use localized names in a script, not just in
 the gui.
 > Ok, if it is only parameter's name, it is not problem to change. I like
 `localized`. Could I submit the code with `localized` parameter instead
 `gui` one?
 Sure, if you tested it with different locale and it behaves as expected.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:8>
