[GRASS-dev] [GRASS GIS] #2856: i.segment: warning "Region consists of only one cell, nothing to update" slows down module
GRASS GIS trac at osgeo.org
Mon Feb 22 06:09:21 PST 2016
slows down module
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  normal       |  Milestone:  7.0.4
 Component:  Imagery      |    Version:  svn-trunk
Resolution:  fixed        |   Keywords:  i.segment region
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by mlennert):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Replying to [comment:3 mmetz]:
 > Replying to [comment:2 mmetz]:
 > > Replying to [ticket:2856 mlennert]:
 > > > In the NC dataset:
 > > > g.region n=221318 s=220073 w=637746 e=639646 res=1
 > > > i.group ortho in=ortho_2001_t792_1m
 > > > i.segment group=ortho at user1 output=ortho_seg_001 threshold=0.01
 memory=2500
 > > > Then, when I try to use the output of this as seeds for the next
 level:
 > > > i.segment group=ortho at user1 output=ortho_seg_002_seeded
 threshold=0.02 seed=ortho_seg_001 memory=2500
 > > > I get tons of
 > > > WARNING: Region consists of only one cell, nothing to update
 > > > The module run takes +/- 1m25.
 > > > When I comment
 [https://trac.osgeo.org/grass/browser/grass/trunk/imagery/i.segment/create_isegs.c#L1086
 line 1086]  in imagery/i.segment/create_isegs.c so that the warning is not
 issued, module run only takes about 20s.
 > > > Is this warning really necessary ? Or is it a bug that it appears in
 this context ?
 > > It is a bug that appears in this context. The warning is justified
 because it appears only when regions are merged. A merged region must
 always consist of more than one cell (merge of two original regions each
 consisting of at least one cell). The bug seems to be an inappropriate
 call to merge_regions().
 > No, an inappropriate call to update_band_vals(). Fixed in r67915,6
 (trunk, relbr70).
 Great. It works great for me. Thanks for the fix.
 Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2856#comment:4>
