[GRASS-dev] [GRASS GIS] #2940: Compiling Grass-7.0.3 under FreeBSD: tplot directory (with log)
GRASS GIS trac at osgeo.org
Sun Feb 28 07:47:22 PST 2016
  Reporter:  pieside  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.0.4
 Component:  Default  |    Version:  7.0.3
Resolution:           |   Keywords:  FreeBSD
       CPU:  x86-64   |   Platform:  Other Unix
Comment (by pieside):
 The problems seems to be an old friend:
 /home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
 freebsd10.2/lib/libgrass_gis.7.0.3.so: undefined reference to `libiconv'
 `libiconv_open'
 `libiconv_close'
 As written in the Porter's Handbook ([https://www.freebsd.org/doc/en/books
 /porters-handbook/index.html]), there are two versions of libiconv in
 FreeBSD: "FreeBSD  10-CURRENT and newer versions have a native iconv in
 the operating system (in libc). On earlier versions, converters/libiconv
 was used as a dependency". So we have a System iconv and Libiconv iconv
 (/usr/local/include/iconv.h).
 One way to overcome this is to deinstall and remove
 /usr/local/include/iconv.h. But some really important softwares depend on
 it: "Despite the default implementation of iconv enabled by default in
 libc, a few ports (like [http://www.freshports.org/devel/glib20/)] depend
 on converters/libiconv again due to missing functionality in the base
 iconv implementation" (written in the /usr/ports/UPDATING file).
 Another solution is suggested in this post (http://osdir.com/ml/grass-
 development-gis/2014-12/msg00435.html). I did add "ICONVLIB = -liconv" in
 include/Make/Platform.make but it doesn't compile for me.
 What all this evoke to you?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2940#comment:2>
