[GRASS-dev] [GRASS GIS] #2846: g.gui.rlisetup: show where new config file is created
trac at osgeo.org
Mon Jan 4 06:19:16 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.4
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by lucadelu):
Replying to [comment:2 mlennert]:
> Replying to [ticket:2846 hellik]:
> > it would be nice if there would be an information of the whole path to
the file which could be copy/paste as input to the r.li.*-modules.
> You should not use the absolute path in the r.li.* modules. Just the
file name. You can list existing files with g.gui.rlisetup. So, normally,
no need to see the absolute path.
I confirm this
> However, ascii output files are also stored in the same path, and this
is a bit more of a nuisance as you then have to navigate there to find the
file. I imagine (but haven't checked) that this was done to ensure that
any other r.li.* module can potentially, easily find the ascii output of
another, but are there many modules that read this kind of output ?
Maybe you can open an enhancement ticket for this?
Can I suggest to close this ticket as invalid? I think it is better to use
g.gui.rlisetup to create or modify the r.li configuration files.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2846#comment:3>
