[GRASS-dev] [GRASS GIS] #2834: v.db.select comand works, sqlite, attribute table does not open
GRASS GIS trac at osgeo.org
Mon Jan 4 07:09:15 PST 2016
  Reporter:  khe          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.3
 Component:  Database     |    Version:  7.0.2
Resolution:               |   Keywords:  v.in.ogr
       CPU:  Unspecified  |   Platform:  Linux
Comment (by khe):
 Hey Martin, thanks for your answer.
  <btw, why do you use o flag?
 I used the "o"-flag in order to override dataset projection (use
 location's projection).
 The command itself ("v.in.ogr") is working. I can open the vector-data of
 the the streams, roads...
 BUT I cannot open the attribute table by using the sqlite-database. I
 connected the sqlite-database, the command "v.db.select" is working.
 When I want to open the attribute table a window opens saying "DMBI-SQLite
 driver error: Unable to scan data...".
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:4>
