[GRASS-dev] [GRASS GIS] #2598: g.extension compilation fails
GRASS GIS trac at osgeo.org
Tue Jan 5 15:37:52 PST 2016
  Reporter:  ewcgrass  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  closed
  Priority:  normal    |  Milestone:  7.0.3
 Component:  Default   |    Version:  svn-releasebranch70
Resolution:  fixed     |   Keywords:
       CPU:  x86-64    |   Platform:  Linux
Comment (by rdzur):
 Markus, in running g.extension to attempt to compile r.damflood on the
 7.0.3RC1 version from http://grassmac.wikidot.com (GRASS 7.0.3 development
 4 Jan 2016) r.damflood does not compile and indicates a SWE.c error which
 I don't know if this is related to the fix you contributed to r67415 or
 some other issue with my system?
 This is the error I currently have:
 g.extension --verbose extension=r.damflood operation=add
 Fetching <r.damflood> from GRASS-Addons SVN repository (be patient)...
 A    r.damflood/SWE.c
 A    r.damflood/SWE.h
 A    r.damflood/main.c
 A    r.damflood/r.damflood.html
 A    r.damflood/dam_failure.png
 A    r.damflood/Makefile
 Checked out revision 67490.
 Compiling...
 mkdir -p
 /var/folders/m3/4x793z_n5sl0v4glj4qlz1sh0000gp/T/tmpP5reiG/r.damflood/bin
 mkdir -p
 /var/folders/m3/4x793z_n5sl0v4glj4qlz1sh0000gp/T/tmpP5reiG/r.damflood/etc
 mkdir -p
 /var/folders/m3/4x793z_n5sl0v4glj4qlz1sh0000gp/T/tmpP5reiG/r.damflood/docs/html
 mkdir -p
 /var/folders/m3/4x793z_n5sl0v4glj4qlz1sh0000gp/T/tmpP5reiG/r.damflood/docs/man
 mkdir -p
 /var/folders/m3/4x793z_n5sl0v4glj4qlz1sh0000gp/T/tmpP5reiG/r.damflood/docs/man/man1
 test -d OBJ.x86_64-apple-darwin14.5.0 || mkdir -p OBJ.x86_64-apple-
 darwin14.5.0
 gcc -I/usr/local/include -g -O2   -arch i386 -arch x86_64
 -I/usr/local/include -I/Applications/GRASS-7.0.app/Contents/MacOS/include
 -DPACKAGE=\""grassmods"\"
 -DRELDIR=\"/private/var/folders/m3/4x793z_n5sl0v4glj4qlz1sh0000gp/T/tmpP5reiG/r.damflood\"
 -o OBJ.x86_64-apple-darwin14.5.0/SWE.o -c SWE.c
 SWE.c:521:9: warning: using floating point absolute value
 function 'fabs' when argument is of integer type
 [-Wabsolute-value]
                                 if
 (fabs(m_u2[row][col]>=1000 )){
 SWE.c:521:9: note: use function 'abs' instead
                                 if
                                     abs
 SWE.c:707:31: warning: using integer absolute value function
 'abs' when argument is of floating point type [-Wabsolute-
 value]
                                 if ((timestep/res_ns*(abs(ab
 s(m_v2[row][col])+sqrt(g*m_h2[row][col]))))>1){
 SWE.c:707:31: note: use function 'fabs' instead
 fabs
 SWE.c:707:27: warning: using integer absolute value function
 value]
 SWE.c:707:27: note: use function 'fabs' instead
                                                       fabs
 3 warnings generated.
 [-Wabsolute-value]
                                 if
                                 if
                                     abs
 value]
 fabs
 value]
                                                       fabs
 main.c:223:9: error: expected parameter declarator
   char* strcat(char* s, const char* ct);
 /usr/include/secure/_string.h:125:38: note: expanded from
 macro 'strcat'
   __builtin___strcat_chk (dest, src, __darwin_obsz (dest))
 /usr/include/secure/_common.h:39:62: note: expanded from
 macro '__darwin_obsz'
 #define __darwin_obsz(object) __builtin_object_size (object,
 _USE_FORTIFY_LEVEL > 1 ? 1 : 0)
 /usr/include/secure/_common.h:30:32: note: expanded from
 macro '_USE_FORTIFY_LEVEL'
 #    define _USE_FORTIFY_LEVEL 2
 main.c:223:9: error: expected ')'
 macro 'strcat'
 main.c:223:9: note: to match this '('
 macro 'strcat'
 /usr/include/secure/_common.h:39:53: note: expanded from
 main.c:223:9: warning: type specifier missing, defaults to
 'int' [-Wimplicit-int]
 macro 'strcat'
 /usr/include/secure/_common.h:39:31: note: expanded from
 main.c:223:9: error: conflicting types for
 '__builtin___strcat_chk'
 /usr/include/secure/_string.h:125:3: note: expanded from
 macro 'strcat'
 main.c:223:9: note: '__builtin___strcat_chk' is a builtin
 with type 'char *(char *, const char *, unsigned long)'
 macro 'strcat'
 -o OBJ.x86_64-apple-darwin14.5.0/main.o -c main.c
 1 warning and 3 errors generated.
 make: *** [OBJ.x86_64-apple-darwin14.5.0/main.o] Error 1
 ERROR: Compilation failed, sorry. Please check above error messages.
 Thanks for any ideas...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2598#comment:14>
