[GRASS-dev] Using GRASS addons in R on Windows
Helmut Kudrnovsky hellik at web.de
Fri Jan 8 01:39:01 PST 2016
pvanbosgeo wrote
> In Windows running R from within GRASS (latter installed via OSGeo4W)
> works fine, except that it can't seem to find the GRASS addons I
> installed (with g.extension), not using rgrass7 nor directly using
> system(). On Linux this is no problem, I can run any installed addon.
> Any ideas how to solve this?
what does echo %PATH% in the osgeo4w shell within the winGRASS session
print?
is the e.g. C:\Users\xy\AppData\Roaming\GRASS7\addons\bin included?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-GRASS-addons-in-R-on-Windows-tp5244240p5244241.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
