[GRASS-dev] [GRASS GIS] #2814: digitizer crashes, leaves vector broken
GRASS GIS trac at osgeo.org
Fri Jan 8 02:35:21 PST 2016
  Reporter:  harrikoo     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  blocker      |  Milestone:  7.0.3
 Component:  wxGUI        |    Version:  7.0.2
Resolution:               |   Keywords:  digitizer, vector
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by harrikoo):
 Replying to [comment:15 mlennert]:
 > Replying to [comment:14 martinl]:
 > > I am not sure of originally reported issue is fixed (there is no undo
 mentioned)
 > I've tried to reproduce, but can't. We would need a reproducible
 example...
 I have followed this discussion with interest. I could reproduce the bugs
 discovered by [comment:1 mlennert], but the results were actually not the
 same. In my original case, the resulting vector was so corrupted, that it
 could not be fixed, nor opened again with g.gui.vdigit; in mlennert's bugs
 the vectors could be opened with g.gui.vdigit after rebuilding the
 topology. And it is true, that in my case, ''undo'' never played any part.
 So my statement would be, that the bug in my original report is ''not''
 fixed; but since I cannot figure out how to reproduce it, I would also
 say, that the ''blocker'' status might be a bit too strong for this one.
 But it was good to have other bugs fixed. (I did have the feeling that the
 undo/redo-buttons should not be touched.) I'll try to figure out if there
 is a consistent way to reproduce my bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2814#comment:16>
