[GRASS-dev] [GRASS GIS] #2755: Commandline switch "/S" is not working anymore
GRASS GIS trac at osgeo.org
Tue Jan 12 03:16:45 PST 2016
  Reporter:  derseppel     |      Owner:  grass-dev@…
      Type:  defect        |     Status:  new
  Priority:  normal        |  Milestone:  7.0.3
 Component:  Installation  |    Version:  7.0.1
Resolution:                |   Keywords:  wingrass
       CPU:  Unspecified   |   Platform:  MSWindows 7
Comment (by derseppel):
 Replying to [comment:6 neteler]:
 > Replying to [comment:4 DerSeppel]:
 > > Will it will be fixed in Version 7.0.3 or is it deferred again?
 > Would you want /S to automatically install these (needed) MS Visual C++
 Packages or to skip them?
 Depends on how this will be implemented.
 If it checks which versions are already installed and then just installs
 the missing versions, it would be nice.
 But for me it will also be Ok if all VC++ installations are skipped when
 the needed versions are documented somewhere easy to find.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2755#comment:7>
