[GRASS-dev] strange behavior of gselect.Select
Luca Delucchi lucadeluge at gmail.com
Tue Jan 12 04:50:45 PST 2016
Anna sorry for the delay in the answer
On 30 December 2015 at 16:51, Anna Petrášová <kratochanna at gmail.com> wrote:
> The TextCtrl must have wx.TE_PROCESS_ENTER style set, that might be the
> problem.
ok, in my case I'm speaking about a wx.combo.ComboCtrl but probably is
the same. Could I add an option style (set by default to None) in
Select class of gselect.py?
> I was dealing with this by checking the existence of the typed map after
> every typed letter. This can slow it down little bit during typing, so I am
> not sure which solution is actually better. With the event bound to Enter,
> users sometimes don't understand they have to press Enter.
I agree with this, I also have no clear idea about the better
solution, other opinions?
> Anna
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
