[GRASS-dev] [GRASS GIS] #2864: Add link to source code in the documentation pages.
trac at osgeo.org
Tue Jan 12 04:52:49 PST 2016
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.4
Component: Docs | Version: svn-releasebranch70
Resolution: | Keywords: open science, access
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
Thank you all,
As far as I am concerned, the two lines seems cleaner to me. Now with
regard to the link itself.
1. I am not sure if hard-coding the link to trunk is the best option.
Since the documentation of multiple GRASS versions are online (i.e. 6.4,
7.0, 7.1) I think that the link should point to the respective branch.
2. Since I guess that many users like myself don't have any particular
knowledge of the GRASS code structure, in order to make this even more
useful I think that the links themselves should directly point to the
directory that contains the command in question.
I think that these two goals are not too hard to be achieved. E.g.
assuming that we know on which branch we are something like this would
give as a dictionary mapping each command to the correct link (you need to
execute it from the repository's root directory.
import os, fnmatch, urlparse
grass_branch = 70
grass_base_dir = "."
branch_source_url = {
64:
"https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/",
70:
"https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/",
71: "https://trac.osgeo.org/grass/browser/grass/trunk/",
base_url = branch_source_url[grass_branch]
grass_command_paths = {}
grass_command_pattern = r'[a-zA-Z0-9]*.[a-zA-Z0-9]*'
for root, dirs, files in os.walk(grass_base_dir):
for name in dirs:
if fnmatch.fnmatch(name, grass_command_pattern):
grass_command_paths[name] = urlparse.urljoin(base_url,
os.path.join(root, name))
from pprint import pprint
pprint(grass_command_paths)
Expected output:
{'English.lproj':
'https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/macosx/app/English.lproj',
'MainMenu.nib':
'https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/macosx/app/English.lproj/MainMenu.nib',
'd.barscale':
'https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/display/d.barscale',
'd.colorlist':
'https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/display/d.colorlist',
'd.colortable':
'https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/display/d.colortable',
'd.correlate':
'https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/scripts/d.correlate',
Mind you that there are a few false positives, but they should not be a
problem since `pgm` in
`mkhtml.py` will not match them. Of course, making the regex stricter is
always possible.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2864#comment:8>
