[GRASS-dev] [GRASS GIS] #2755: Commandline switch "/S" is not working anymore
GRASS GIS trac at osgeo.org
Tue Jan 12 05:35:46 PST 2016
  Reporter:  derseppel     |      Owner:  grass-dev@…
      Type:  defect        |     Status:  new
  Priority:  normal        |  Milestone:  7.0.3
 Component:  Installation  |    Version:  7.0.1
Resolution:                |   Keywords:  wingrass
       CPU:  Unspecified   |   Platform:  MSWindows 7
Comment (by derseppel):
 what about installing MS VC++ in "normal" (GUI) mode and just skip it in
 silent mode.
 I think people (Admins) using the /S switch should be smart enough to find
 out what is missing (as I already said, it should be documented
 somewhere).
 If not, maybe your error message isn't clear enough. As you see, the
 problem can be solved on many stages.
 ''I tend to wontfix for this ticket.'' <-- Worst you can do. I don't think
 taht I am the only one who needs a silent install to deploy software in a
 huge environment.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2755#comment:10>
