[GRASS-dev] [GRASS GIS] #719: v.edit tool=break: breaking more then 6 coords and producing of an unexpected line
GRASS GIS trac at osgeo.org
Wed Jan 13 04:25:42 PST 2016
unexpected line
  Reporter:  achim        |      Owner:  martinl
      Type:  defect       |     Status:  reopened
  Priority:  major        |  Milestone:  7.0.3
 Component:  Vector       |    Version:  7.0.2
Resolution:               |   Keywords:  v.edit tool=break
       CPU:  Unspecified  |   Platform:  Linux
Comment (by mlennert):
 Replying to [comment:22 mlennert]:
 > Replying to [comment:21 neteler]:
 > > Replying to [comment:20 mlennert]:
 > > > Looking at this briefly, wouldn't it be enough to port r58512 and
 r5851 to the grass7 branches ? The original fix was only applied to
 grass6.
 > > Sure about r5851? One digit lost?
 > Yes, sorry, this should have been r58512 and r58516 (as mentioned in
 earlier comments by Martin).
 I just tested trunk without and with the above fixes applied. Without I
 can reproduce the issue reported by the OP, with the issue seems to be
 solved. So I took the liberty to forward port both fixes to trunk.
 Please test. I don't know the code well enough to judge the invasiveness
 of this fix and am not sure if this should still go into 7.0.3. Maybe we
 should wait a bit and backport it for 7.0.4 ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/719#comment:23>
