[GRASS-dev] t.vect.observe.strds differences between trunk and release branch
Markus Neteler neteler at osgeo.org
Thu Jan 14 15:24:46 PST 2016
Hi Vero,
On Fri, Jan 8, 2016 at 6:56 PM, Veronica Andreo <veroandreo at gmail.com> wrote:
> Hi devs,
> I was using t.vect.observe.strds and while reading the manual from grass71
> (https://grass.osgeo.org/grass71/manuals/t.vect.observe.strds.html), I found
> that in the Description section a parameter "t_where" was mentioned
> while not listed under Parameters.
Thanks for catching that: I have remove the reference to t_where
parameter t.vect.observe.strds manual as it was deleted in r64560.
> However, this t_where parameter is present for
> t.vect.observe.strds in grass70 manual
> (https://grass.osgeo.org/grass70/manuals/t.vect.observe.strds.html).
> I found in trac that changeset 64560, removes t_where from trunk since it is
> not supported in case of multiple strds sampling, but I did not find
> something similar for release branch. Is there a reason why it should work
> in 70 but not in 71?
I guess it doesn't always work in relbranch70.
Maybe Soeren knows?
Markus
