[GRASS-dev] [GRASS GIS] #2872: "r.info -e" output not compliant with eval
GRASS GIS trac at osgeo.org
Thu Jan 21 05:01:13 PST 2016
 Reporter:  andbal         |      Owner:  grass-dev@…
     Type:  defect         |     Status:  new
 Priority:  normal         |  Milestone:
Component:  Shell Scripts  |    Version:  svn-trunk
 Keywords:  shell, r.info  |        CPU:  x86-64
 Platform:  Linux          |
 I've got an error using the command {{{eval `r.info -e <map_name>`}}}.
 This is the output:
 GRASS 7.1.svn (---):~ > eval `r.info -e map=soilheatflux.dos4`
 bash: unexpected EOF while looking for matching `"'
 bash: syntax error: unexpected end of file
 The error is likely to be correlated to the flags {{{-e}}} because with
 other flag (like {{{-r}}} for example), the command {{{eval}}} works well.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2872>
