[GRASS-dev] [GRASS GIS] #2333: choose python interpreter during the GRASS installation on windows
trac at osgeo.org
Sat Jan 23 14:42:45 PST 2016
Reporter: zarch | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Resolution: | Keywords: windows installer python
| interpreter
CPU: All | Platform: MSWindows 8
Comment (by hellik):
Replying to [comment:26 wenzeslaus]:
> Replying to [comment:25 hellik]:
> > should there in the standalone installer be only the option to choose
the python interpreter or also some check of needed dependencies
(wxwidgets, python win api etc.)? for example my system wide python
installation (installed by another software) isn't compatible to run
winGRASS out of the box
> In [comment:52:ticket:580 ticket 580] Michael is saying that wxPython is
bundled with GRASS GIS and the system Python is used. Is there a way to do
something like this on Windows?
as mentioned at other places, there is no system wide python in windows at
all. users has to do the install for themself, also all the packages
> > how/if should such an option implemented in OSGeo4W-winGRASS too?
> It would have to be implemented for the whole OSGeo4W I suppose. The
reason for doing it there is the same as for the standalone version.
OSGeo4W doesn't contain all the packages available through pip and it
doesn't contain pip.
what about to improve the situation in the underlying Osgeo4w? There are
already some starting efforts regarding pip etc.
> > if not, there would be disparity between different platforms on
windows (standalone, OSGeo4W, QGIS bundled).
> I think the idea is to make it more similar across operating system. On
Linux, one does not have to install Python packages for GRASS separately
or do some workaround to get the already installed there. Mac OS X works
the same if you are (very) lucky.
> OSGeo4W, QGIS-bundled or whatever-bundled might need to use the internal
Python option. Are the install scripts able to handle two options or it is
too difficult?
> > how should our users deal with these many different variants? e.g. for
myself I never work with the standalone installer, prefer the OSGeo4W-
environment as there are quite a lot tools, which can easily be updated.
> There are already different variants. And unless all OSGeo projects
agree on using OSGeo4W exclusively, we will always have them. With
installation of additional packages, I'm not worried about them much. I'm
more worried about them in regard to #2873, but still, Linux, Mac and
standalone would/could be the same, OSGeo4W and QGIS-bundled would be
different.
I'm not quite sure about the effort regarding overcome the differences of
OS at software level. but that's a personal point of view. If you look at
the QGIS ticket at using "system wide python". there is at least some
concern at the windows site of life.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2333#comment:27>
