[GRASS-dev] [GRASS GIS] #2875: Python testsuite failing with UnicodeDecodeError
GRASS GIS trac at osgeo.org
Mon Jan 25 07:50:49 PST 2016
  Reporter:  marisn       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.1.0
 Component:  Tests        |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Linux
Comment (by wenzeslaus):
 Replying to [ticket:2875 marisn]:
 > Unfortunately it is not possible to run tests as test suite is failing
 itself...
 >     module.run()
 >   File ".../grass/pygrass/modules/interface/module.py", line 713, in run
 >     module=self.name, errors=stderr)
 Since this comes from ''grass.pygrass.modules'', can you try the
 ''Module'' class separately?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2875#comment:4>
