[GRASS-dev] [GRASS GIS] #2878: "v.in.ogr -i" throws an error when importing a GeoJSON file containing a single point.
trac at osgeo.org
Thu Jan 28 08:16:45 PST 2016
single point.
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-releasebranch70
Resolution: | Keywords: v.in.ogr v.import
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:12 pmav99]:
> Replying to [comment:10 mlennert]:
> > One question we have to answer is whether GRASS should allow the
creation of mapsets with 0 resolution in any direction, and, if not (as I
think it should be), then what would be a reasonable default when creating
a location from a file containing data with identical coordinates in
either of the directions or with just one point.
> I also tried to create a location using the grass binary and a GeoJSON
file containing a single Point. The location gets created without any
errors/warnings but when you try to open the location you get the
following traceback:
Yes, g.proj should have the same issue, so I think the solution will not
be in v.in.ogr, but at library level. Just no time right now to look into
it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2878#comment:13>
