[GRASS-dev] [GRASS GIS] #2709: pyGRASS Module runs twice from interactive Python prompt
GRASS GIS trac at osgeo.org
Thu Jan 28 11:38:14 PST 2016
  Reporter:  martinl      |      Owner:
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.0.4
 Component:  PyGRASS      |    Version:  unspecified
Resolution:               |   Keywords:  interactive prompt
       CPU:  Unspecified  |   Platform:  Linux
Comment (by neteler):
 I just checked and something is pretty wrong:
 GRASS 7.1.svn (eu_laea):~ > python
 Python 2.7.10 (default, Sep  8 2015, 17:20:17)
 [GCC 5.1.1 20150618 (Red Hat 5.1.1-4)] on linux2
 Type "help", "copyright", "credits" or "license" for more information.
 >>> from grass.pygrass.modules import Module
 >>> Module('g.extension', flags='a')
 List of installed extensions (modules):
 r.skyview
 i.segment.hierarchical
 Module('g.extension')                 <<== ????
 Anyway, now entering the next command from the original report:
 >>> Module('r.mask', flags='r')
 ERROR: No existing MASK to remove
 Description:
  Maintains GRASS Addons extensions in local GRASS installation.
  Downloads and installs extensions from GRASS Addons repository or other
 source into the local GRASS installation or removes installed extensions.
 Keywords:
  general, installation, extensions, addons, download     <<<-- ?????
 Usage:
  g.extension [-lcgasdift] extension=name operation=string [url=url]
    [prefix=path] [proxy=proxy[,proxy,...]] [--help] [--verbose] [--quiet]
    [--ui]
 Flags:
   -l   List available extensions in the official GRASS GIS Addons
 repository
               default: $GRASS_ADDON_BASE
       proxy   Set the proxy with: "http=<value>,ftp=<value>"
 ERROR: Options <extension>, <-l>, <-c>, <-g> and <-a> are mutually
 exclusive
 Description:
 Keywords:
 Usage:
    [--ui]
 ... now there is some "ghost process"... finishing in a loop:
 exclusive
 ^CTraceback (most recent call last):
   File "/home/neteler/software/grass71/dist.x86_64-pc-linux-
 gnu/scripts/g.extension", line 134, in <module>
     import shutil
   File "/usr/lib64/python2.7/shutil.py", line 5, in <module>
   File "<stdin>", line 1, in <module>
 gnu/etc/python/grass/pygrass/modules/interface/module.py", line 526, in
 __init__
     self.__call__(*args, **kargs)
 gnu/etc/python/grass/pygrass/modules/interface/module.py", line 583, in
 __call__
 KeyboardInterrupt
     return self.run()
 gnu/etc/python/grass/pygrass/modules/interface/module.py", line 713, in
 run
 __init__
     module=self.name, errors=stderr)
 gnu/etc/python/grass/exceptions/__init__.py", line 68, in __init__
         msg = _("Module run %s %s ended with error") % (module, code)
 __call__
 __call__
 run
 __call__
     return self.run()
 run
 __call__
     return self.run()
 run
 __call__
     return self.run()
 gnu/etc/python/grass/pygrass/modules/interface/module.py", line 706, in
 run
     stdout, stderr = self.popen.communicate(input=self.stdin)
   File "/usr/lib64/python2.7/subprocess.py", line 796, in communicate
     self.wait()
   File "/usr/lib64/python2.7/subprocess.py", line 1384, in wait
     pid, sts = _eintr_retry_call(os.waitpid, self.pid, 0)
   File "/usr/lib64/python2.7/subprocess.py", line 476, in
 _eintr_retry_call
     return func(*args)
 KeyboardInterrupt
Ticket URL: <https://trac.osgeo.org/grass/ticket/2709#comment:6>
