[GRASS-dev] [GRASS GIS] #2857: d.rast.num fails in GUI because the constrain display resolution fails
GRASS GIS trac at osgeo.org
Fri Jan 29 12:38:11 PST 2016
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.1.0
 Component:  wxGUI       |    Version:  svn-trunk
Resolution:              |   Keywords:  display resolution, d.rast.num,
       CPU:              |  mapdisp
  Unspecified            |   Platform:  Linux
Comment (by wenzeslaus):
 I did bisect search and found that ''d.rast.num'' is broken after r65205.
 To test, add raster map layer and switch on the ''Constrain display
 resolution to computational settings'' in ''Display resolution'' in Map
 Display status bar.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2857#comment:1>
