[GRASS-dev] [GRASS GIS] #3050: Set size in d.northarrow
GRASS GIS trac at osgeo.org
Thu Jun 2 12:51:07 PDT 2016
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:              |     Status:  new
  enhancement            |
  Priority:  minor       |  Milestone:  7.3.0
 Component:  Display     |    Version:  svn-trunk
Resolution:              |   Keywords:  d.northarrow, cartography, gsoc2016
       CPU:              |   Platform:  Unspecified
  Unspecified            |
Comment (by wenzeslaus):
 Replying to [comment:1 lazaa]:
 > Replying to [ticket:3050 wenzeslaus]:
 > >All symbols are scaled to one common size, that's good, but this size
 should be further rescaled by a value of a `size` option.
 > If user doesn't use {{{size}}} manually tuned size will be used. But if
 user writes {{{size=25}}} for some symbols it will have increasing size
 effect and for others decreasing size effect.
 I don't know what is better if to scale, as I suggested, which is
 different behavior from all the other modules (so it might be better to
 call it `scale`), or if it is better to overwrite the size, as you suggest
 and consequently make it potentially harder for the user (symbols in
 d.vect behave the same but they have more similar sizes).
 For now, I suggest to skip this issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3050#comment:2>
