[GRASS-dev] [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
Michael Barton Michael.Barton at asu.edu
Mon Jun 6 12:37:32 PDT 2016
OK. This means the /usr/local/... path is hardwired into the wxPython Mac binary itself. Not sure if this changes how we need to deal with this.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jun 6, 2016, at 12:15 PM, Adam Dershowitz <adershowitz at exponent.com<mailto:adershowitz at exponent.com>> wrote:
I just downloaded it, and tried it.  No luck.  It still doesn’t find the libraries that it needs:
'/Applications/GRASS-7.3.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.10 found.
Cleaning up temporary files...
Starting GRASS GIS...
  File "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/gis_set.py", line 31, in <module>
    from core import globalvar
  File "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/globalvar.py", line 96, in <module>
    import wx
  File "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/__init__.py", line 45, in <module>
    from wx._core import *
  File "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core.py", line 4, in <module>
    import _core_
ImportError: dlopen(/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core_.so, 2): Library not loaded: /usr/local/lib/wxPython-3.0.2.0/lib/libwx_osx_cocoau-3.0.0.2.0.dylib
  Referenced from: /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core_.so
  Reason: image not found
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the -text flag.
Exiting...
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions...none found.
[Process completed]
-- Adam
From: Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>
Date: Monday, June 6, 2016 at 2:50 PM
To: Adam Dershowitz <adershowitz at exponent.com<mailto:adershowitz at exponent.com>>
Cc: GRASS developers <grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>>, GRASS users <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>, Helena Mitasova <hmitaso at unity.ncsu.edu<mailto:hmitaso at unity.ncsu.edu>>, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>>
Subject: Re: [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
Adam and others,
Yet another GRASS 64 bit. I just uploaded to the GRASS for Mac site.
I tried something else. I am hoping that this works with SIP enabled in El Capitan and does not add Anaconda as a required dependency.
If you have a chance, give it a try.
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=CwMF-g&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=EptVyHvN5Hy-kJAyE5zVpjKVi-Hj12JwOOKM6yUgzF0&s=34kfotLDUf5mRfMlJY9uXiBzLxZFhHfdFsRiE5hwz0s&e=>, http://csdc.asu.edu<https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=CwMF-g&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=EptVyHvN5Hy-kJAyE5zVpjKVi-Hj12JwOOKM6yUgzF0&s=M_LT_GhsO_-fWH5lR5tqThIl7ZwPXZN68wY9zdZVpwM&e=>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160606/431a750b/attachment-0001.html>
