[GRASS-dev] [SoC]Week-4 WebGrass
Mayank Agrawal
mayankagrawal333 at gmail.com
Tue Jun 21 11:32:08 PDT 2016
Hi everyone,
I am student working on the WebGrass project for this GSoC. I was making
the dialog boxes of different modules in grass. While doing this, I come
across a problem. I am using the xml files of these modules using command (
x.module --interface-description). When a dialog box opens, there are many
options. For example, for the v.buffer (v.buffer --interface-description),
there is option for "input vector map" and "output vector map" (screenshot
<https://cloud.githubusercontent.com/assets/12744703/16241571/e05a7402-380b-11e6-9701-9c211da3ebc3.png>).
When you see the xml
<https://gist.github.com/mayank33/5dccaa844787abee280c0291a1561ed2>, then
you will notice "input vector map" is under label
<https://gist.github.com/mayank33/5dccaa844787abee280c0291a1561ed2#file-buffer-xml-L12>
tag
and "output vector map" is under description
<https://gist.github.com/mayank33/5dccaa844787abee280c0291a1561ed2#file-buffer-xml-L95>
tag.
Though both are shown at same place in dialog box. Same thing is done at
many places in different modules. I want to know whether it is on purpose
or some kind of error as this makes the parsing of xml for generation of
dialog box, a little bit tricky. At some places, description tag is used
and somewhere label tag is used. Also any help in this regard(parsing) will
be highly appreciated.
Mayank Agrawal
Lab for Spatial Informatics
IIIT Hyderabad
Hyderabad
On Sun, Jun 19, 2016 at 4:14 PM, Mayank Agrawal <mayankagrawal333 at gmail.com>
wrote:
> Hi everyone,
> I am Mayank Agrawal and I am working on webgrass.
> my report for the week 4
> Q. What did you get done this week?
> - parsing of the xml files
> - Creation of new window.
> - working UI of module windows.
> - calling and clicking of modules.
> commit
> <https://github.com/rashadkm/webgrass/pull/10/commits/b5f1ff39b315a819af2a95a88cf6e69f3a2c2a70>
> Screenshot
> <https://trac.osgeo.org/grass/attachment/wiki/GSoC/2016/WebGrass/ModuleUI1.png>
> Status - Clicking on the different modules and generation of UI
> Q. What do you plan on doing next week?
> - There is some inconsistency with parsing for generation of different
> modules. Removing those.
> Q. Are you blocked on anything?
> Not rite now.
> Mayank Agrawal
> IIIT Hyderabad
> Hyderabad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160622/7a285278/attachment.html>
