[GRASS-dev] [GRASS GIS] #2957: t.rast.what throw error while running on large number of maps
GRASS GIS trac at osgeo.org
Fri Mar 4 03:02:29 PST 2016
 Reporter:  spareeth               |      Owner:  grass-dev@…
     Type:  defect                 |     Status:  new
 Priority:  normal                 |  Milestone:  7.1.0
Component:  Temporal               |    Version:  svn-trunk
 Keywords:  temporal, t.rast.what  |        CPU:  Unspecified
 Platform:  Linux                  |
 The temporal module t.rast.what throw error when nprocs is not used, while
 running on large number of maps (10,800 raster input in my case).
 The error is:
   File "/usr/local/grass-7.1.svn/scripts/t.rast.what", line 526, in
 <module>
     main(options, flags)
   File "/usr/local/grass-7.1.svn/scripts/t.rast.what", line 266, in main
     mod(map=map_names, output=file_name)
 NameError: global name 'map_names' is not defined
 It works if I give nprocs option; for example nprocs=4
 With smaller number of maps, with or without nprocs work fine.
 Sajid
Ticket URL: <https://trac.osgeo.org/grass/ticket/2957>
